projected vs non-projected plugs
so this would mean moving from a TR6 (-6) heat range to a BR7 (-7) is actually a (-8).
according to what ive always known kierstyn the 3177 would be a step colder from the 4177
a tr6 and a br7ef is not a direct comparison.
a tr6 and a br6ef would be a better show.
not sure how the heat range differs between the two.
as noted, the projected tip gets hot as ****, so the non projected couold be "considered" cooler seeing its out of harms way.
i would think a h/c car with <100rw pill would be ideal with a br6ef
Mostly track running, with some street driving interspersed.
Are these halfway decent to run on the street as a DD plug?
i usually do mine around .032
i dont have efi, idle can be more rough with the br series of plugs.
Robert
Some guys that run dedicated nitrous drag cars actually cut the ground strap back right to the edge of the electrode. They due this to have even faster heat transfer. Now will this cause other issues? I don't know, as I have never done it personally, but certainly think about it from time to time. I will see if I can find the picture of this.
Robert
Do you guys want to get into this part of the plugs? I have been working on an article for a few years and gathering data, and have a rough draft on the fuel ring. Well I have other areas covered too if moving to another area of reading the plug would be helpful after this area? its' mostly insight that allows anyone to tune via their own plugs...
Robert
while that plug looks great for a tune up to me, some others would disagree and say you could go a jet leaner.
there is tons of good(and bad) info over on yellow bullet in the nitrous section on plugs and plug readings.
