Botttle warmer
Old Dec 18, 2003 | 09:09 PM
DBR TSI's Avatar
Default Botttle warmer
I was wondering how a few of you have a bottle warmer mounted. i have mine on top of the bottle right in the center of it, I was told a few days ago i had it on the wrong way. That it should be mounted under the bottle toward the rear of it. Just wondering if there is any difference between the two.
Old Dec 22, 2003 | 10:08 PM
LS1Formula98's Avatar
I have mine mounted in the middle too, I have no problem getting mine heated up. I don't understand how you could have it in the wrong area, as long as it is on the bottle.
Old Dec 23, 2003 | 06:56 AM
4thGENRETARD's Avatar
As close to the bottom as possible unless your bottle is upside down. N2O is in liquid form and when the bottle starts emptying the liqhid is at the bottom.
Old Dec 23, 2003 | 02:54 PM
Elite_Hot_Rod's Avatar
Mine heater is placed on the bottle the same as yours, with the open space between the ends on the bottom. I don't know how much difference it would make to have the space at the top rather than at the bottom once the bottle is hot. I see what they were saying though, heat rises so you could say that you want more of the heater around the bottom of the bottle rather than the top.
Old Dec 25, 2003 | 03:02 PM
Well allmost, what you want is to heat the mixture of nitrous which makes it expend and gives you more pressure. If you heat the part of the bottle which is not in direct contact with the liquid inside, it will take longer and is less efficient.
