Looking for info on nitrous controllers
Old Jan 11, 2010 | 09:49 PM
Mean87SS's Avatar
Default Looking for info on nitrous controllers
I've been looking for a nitrous controller for some time now, hopfully someone will have suggestions...
I have a Cam car looking to run a wet shot, and possible two stages.
I am planning on running a two step and having the nitrous spray as soon as I release the two step or have a delay as traction allows. As well as I'm looking to have it set for a specific RPM...
Any suggestions?
Thanks all!
Old Jan 11, 2010 | 10:25 PM
DiabloFormula's Avatar
I'm running a NOS Mini controller, just have it setup for a straight 150 shot off the line right now, but plan on splitting it up using the controller when I go 200. I also have the MSD 2 step coming so I'll have to figure out how I'm going to wiring that up into my setup so I can still spray off the line.
Pm'ed ya as well.
Old Jan 11, 2010 | 10:28 PM
89ROC-Z's Avatar
could look at the microedge HSW has
Old Jan 12, 2010 | 10:01 AM
ls1redline's Avatar
+1 ^^^^^Have it, Love it, recommend it, period!!
Old Jan 12, 2010 | 11:56 AM
Mean87SS's Avatar
Does anyone knows if the HSW Microedge can cantrol two stages progressivly? And have the ability to do what I want with a 2 step?
Old Jan 12, 2010 | 11:59 AM
streetassasin's Avatar
the microedge + has a progressive 2 stage setting, not too sure about the 2 step
Old Jan 12, 2010 | 03:53 PM
Chris@NitroDaves
Guest
Posts: n/a
We have had several customers use the FJO progressive with great results...
http://www.nitrousoutlet.com/catalog...35&product=952
Old Jan 14, 2010 | 10:36 AM
Nick@HSW's Avatar
The microedge + can control 2 stages progressively as well as a whole bunch more. You can also use it in conjunction with a 2 step as well.
Nick
Old Jan 15, 2010 | 11:59 AM
daschra79's Avatar
Nick
Does it work with a trans brake?
Old Jan 15, 2010 | 12:16 PM
JL ws-6's Avatar
Race your car!
I think it will yes
Another option, if you wanted to spend a little bit moer $ would be an Nos launcher. That can do alot of stuff like what you're looking to do as well.
The Harris piece for the $ is a good deal. The FJO piece, is also a capable part.
Old Jan 15, 2010 | 05:38 PM
daschra79's Avatar
Originally Posted by JL ws-6
I think it will yes
Have you used the NOS launcher?How do you like it?anyone else use it?
Old Jan 16, 2010 | 05:34 AM
JL ws-6's Avatar
Race your car!
I've used one yes... works pretty good. You can turn 1 kit on and off, progress, turn one on when you leave, turn it off then turn on a 2nd kit, then turn the first one back on for a 3 stage effect with 2 kits on the car if you want, youc an even turn both off and back on if you know there's a bald spot in the track, progress them back in, have stuff coem on and off based on rpm, etc.
The thing's run by a laptop, or there's a touch screen you can get too. Nice piece, expensive, alot more then the harris or fjo, but I think it can do a little more too, not 100% on that, but it's a good piece.
Old Jan 16, 2010 | 04:59 PM
daschra79's Avatar
It does look like a really nice setup, but I think it's more than I need at this time.
Old Jan 17, 2010 | 06:25 AM
JL ws-6's Avatar
Race your car!
It's probably more then most people need.
Old Jan 18, 2010 | 08:20 AM
Nick@HSW's Avatar
They're actually really comparable. I mean NOS does offer progression based off of MAP sensor. But we also offer progressive curves per gear so you really can dial in each gear separately if you wanted to. I also think they're rich/lean shutdown is only compatible with the holley stuff. Might also be something worth looking into if you have another brand wideband. They use a laptop or optional touch screen while ours is all programmed via controller. We also have the file system which allows you to have 3 saved files that you can switch to on the fly. But honestly the NOS and MicroEDGE + are very similar...
Nick
Old Jan 18, 2010 | 08:33 AM
JL ws-6's Avatar
Race your car!
There's a better comparison. I know both can do alot, wasn't 100% on the details, now everyone knows
Old Jan 20, 2010 | 07:49 PM
lilicedout24's Avatar
Thumbs up
I think it will yes
i have the fjo nib and ligenfelter 2 step lauch used twice pm me i no longer need these items. i wouldn't mind selling them at a great deal for both shipped
Old Jan 20, 2010 | 08:50 PM
kidcamaro98's Avatar
how was the install on the microedge??
Old Jan 21, 2010 | 11:32 AM
Nick@HSW's Avatar
We host our instructions online...feel free to browse through them and if you have any questions just ask.
Nick
Old Jan 21, 2010 | 12:00 PM
GrimReaper's Avatar
I had used the FJO with my BS3 this summer on my car, my experiance with that product was not really good. "I" could never get it to completely work right all the time. I cant wait to switch to something else. This is just "my" experiance fwiw.
