It is ok for me to run NOS with the setup I have?
Old Dec 19, 2003 | 08:19 PM
SuperSlowSSLS1's Avatar
Default It is ok for me to run NOS with the setup I have?
Ok this is what I have...
02 ls1 6 speed..
5.3 heads ported by TEA to 1.5
comp cam 224 224 581 581 112
FLP's and a K@N FIPK intake....
right now the car makes about 410hp and 400tq
The best I can run out of it is 12.5 at 118 with a 1.9 60" on Nitto's
I want to spray a 100 shot on the car.. Not schure what kit to go with or.. If its even safe to put NOS on the car.. Condsidering I no with
these heads my compression is going to be like 11.1 prob.. Not schure exactly what it is....
Is it ok to spray with this setup?
If so what kit? and how much schould I spray??
Thank You..
Frank
Old Dec 19, 2003 | 09:32 PM
Colonel's Avatar
TR-6 plugs.
Timing advance set to about 23 degrees.
O2s at 910-.950mv.
75 shot.
You'll be safe.
Upgrade the fuel pump (and injectors too for a dry shot) and drop the timing back a little more to spray more. Unleaded race gas is also a really good idea.
Old Dec 19, 2003 | 10:04 PM
What type of kit.. Is going to work safe.. And is a 75 shot the most i can spray since i have heads and cam.. And stock bottom end.. And high compression..
whats the safest and best kit.. and can I spray a 100 shot.?
Old Dec 19, 2003 | 10:32 PM
Nine Finger 02 Z28's Avatar
You seem to be having Major Traction Issues and NOS will only make it worse.
Old Dec 19, 2003 | 11:02 PM
I dont think that iam having that bad of traction prob.. At the track.. yes.. but not on the street..
what kit is the best i can go with for being safe and performance..
with my high compression heads and cam..
can i spray a 100 shot..
what about a direct port system.. Is that not a good kit to go with or yes?
Old Dec 19, 2003 | 11:22 PM
schould I go with like a 5177 kit thats dry and just spray like a 125 pill..
Old Dec 20, 2003 | 10:45 AM
what NOS set up can I get.. to run low 11 sec times..
Old Dec 20, 2003 | 01:23 PM
Caqn Some One Please Help.. Me I Have Decided Not Go Try To Go With A Bigger Motor The 383 Kits Are To Much $$$$
I Would Like To Spray But Dont No What I Can Spray With What I Have.
To Be Safe.. What Kit Schould I Go With And How Much Schould I Spray.?
Old Dec 21, 2003 | 11:35 AM
silverTA's Avatar
there is a guy got the same set as you , he dyno 420rwhp and he was running 11.5 (na)
he was spraying 150 shot wet kit (mods svo 30Inj and bigger intank fuel pump )
Old Dec 22, 2003 | 12:37 AM
he ran 11.5 with the 150 shot??
Old Dec 22, 2003 | 11:15 AM
What kit was did he have? All I want to do is spray like a 100 shot i dont want to risk blowing up my motor..
Old Dec 24, 2003 | 02:30 AM
silverTA's Avatar
he was running 11.5 NA with out not nitrous
i don't have his time with 150 shot(nx shark nozzle )
Old Dec 25, 2003 | 04:50 AM
chadtn's Avatar
With traction you should be in the 11's on the motor. I'd work on that before you try adding more power.
My six speed 02 Z28 ran 11.72@118mph with a lid, cutout, and a 135 dry shot of nitrous
Old Dec 25, 2003 | 08:59 AM
TWINK's Avatar
Get A Nx Efi Kit And Put A Set Of Tr-6's And A 75 Shot W A Window Switch And Spray The Crap Out Of It
Old Dec 26, 2003 | 10:52 PM
TWINK's Avatar
superslowssls1 have u got a nitrous kit yet
Old Dec 28, 2003 | 10:52 PM
jerry ta's Avatar
hi frank, ask the colonal with kit is best, and look at his files, Ive still got the new nos kit thanks jerry
