Anyone making 550HP on a stock bottom 346ci???
The fuel pumps on 97-02 and early 03's are stupidly easy to change. All he will hafe to do is remove the left rear tire and the heat sheild covering the fuel tank and he will have access to the pump. On late 03's and 04's they moved the pump to the top of the tank reqiuring you to remove the tank from the car to get to the fuel pump.
I wouldnt even change the pump. I would just do a KB BAP and call it a day. Thats what I have (along with 39 lb injectors) and im making over 600 to the wheels on spray.
Car is an 01 Z with heads, cam, etc.... Makes 450hp to the rear and was just tuned about 2 months ago. Ordered up my new plate kit and thinking of a nice 100hp shot but dont want to scatter the bottom end. Car might see spray 4-5 times a year. This is not for the street but instead the track and dyno. I obviously will have it tuned for the bottom I just want to watch my limits. I have read in the past that either 500hp or 600hp is about the limit but dont remember which rule of thumb it was. HAHA
Idont think I need a hot wire kit for the fact I have a 140A Nations alternator and my voltage even with 3000 watts of car audio never drops or dims.
As for the boost a pump it looks like my next mod. I have not decided on the fuel system yet. That is still a consideration. Thanks guys
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
i read that ur car is a show car but u will use the nitrous a few times... i glanced through this thread i dont think anyone mentioned this but y not a dedicated fuel system? just curious i know its expensive and all but u can then put 93 in the car and then run 110 in the dedicated tank for when u spray.. from what i understand that will help eliminate the chance of detonation.. i know its over kill for a 100shot but if u ever wanted to spray more u wouldnt have any problems.. im just throwing it out there to see what other people think about it.. http://www.nitrousoutlet.com/catalog...73&product=946
