nitrous plate install suggestions
Old Feb 13, 2010 | 04:28 PM
ssman00's Avatar
Default nitrous plate install suggestions
I have a FAST 92/92 to install on the car with the FAST fuel rails, im thinking of getting the fbody specific 92mm plate kit. i was wondering what the best way to hook up the fuel on the FAST intake to work with the nitrous and fuel rails
Old Feb 13, 2010 | 07:49 PM
ssman00's Avatar
anyone?
Old Feb 13, 2010 | 08:29 PM
Peeler12's Avatar
Bump for ya pal.
Old Feb 14, 2010 | 10:47 AM
ssman00's Avatar
somebody has to be running this setup
Old Feb 14, 2010 | 01:24 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
there are a couple different ways to do it depending on how you set yours up.
Do you have any pictures?
Old Feb 14, 2010 | 02:26 PM
ssman00's Avatar
its not yet together or on the car im open to suggestions
Old Feb 14, 2010 | 06:42 PM
ssman00's Avatar
its the Fast 92/92 Intake with the red FAST fuel rails and i have the FAST braided kit to hook up the fuel. iv got cash waiting to order the nitous kit ans i would like the fbody specific kit with the pre bent haqrd lines. i just would like to know how to run the fuel lines and stuff to make it work with the FAST rails
Old Feb 14, 2010 | 07:44 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
all it should take is one extra fitting.....give us a call and we can go over the details with you and send it all together. I usually have the stuff you will need in stock
Old Feb 14, 2010 | 11:16 PM
ssman00's Avatar
ok I will call you in the morning thanx
Old Feb 15, 2010 | 07:52 AM
Nick@HSW's Avatar
Just run a 6AN gauge port adapter depending on how large of a shot this will be sufficient.
Nick
Old Feb 15, 2010 | 10:35 PM
Nitro Dave's Nitrous Outlet's Avatar
Grant was asking me about this today so I assume it was you he was talking to. There are a few options to do what you are needing. The reason why the guys wanted to know how you are feeding the rail is so we can determain which way and fittings would give you the cleanest looking install. You coukd do the -6 adapter like Nick suggested but there may be some sexier options.
Did you purchase a fuel rail plumbing kit from someone? If so who and we will look at what they are supplying.
Dave
