Anyone running N20 on button?
Old Feb 15, 2010 | 05:58 PM
1904gto's Avatar
Post Anyone running N20 on button?
just curious to see if anyone running it on a botton maybe on their shifter or steering wheel, or has everyone switched over to WOT & Progressive controllers
and if i could see pics
thanks
Old Feb 15, 2010 | 06:17 PM
jman54002's Avatar
yep...well use too...I used the horn button on the steering wheel. Easy to hold on that way plus it is hidden. now I am on a micro switch of the throttle body.
Old Feb 15, 2010 | 07:41 PM
87silverbullet's Avatar
Yup I used the steering wheel controls to shoot my 2 stage setup. Preset button for the first and am/fm button for the second. All on the left side so the car can be shifted.
Old Feb 15, 2010 | 07:47 PM
1904gto's Avatar
do you have a wiring diagram to wire it into the controls? i have a GTO but im sure the wiring will b kinda smiliar
and thanks for the help
Old Feb 15, 2010 | 08:31 PM
BakaN20's Avatar
I would be surprised if anyone was still using a button activation, especially considering how cheap a wot switch is now and how much more dangerous it is to run a button. I would like to see some button setups though.
Old Feb 15, 2010 | 09:12 PM
spaz1's Avatar
I would still run a wot switch to arm the push button just for safety.
Old Feb 15, 2010 | 09:46 PM
1904gto's Avatar
thats good idea
Old Feb 15, 2010 | 10:24 PM
Nitro Dave's Nitrous Outlet's Avatar
I have set up many different combinations. There is nothing wrong with using a button when used in conjunction with a windowswitch and wot activation. The button just gives you the ability to introduce the nitrous on the fly at what ever point you may want it.
Dave
Old Feb 16, 2010 | 07:29 AM
I run mine like that so I can play on the street with the 2 different shots. My converter is big enough that it will flash and be in a good rpm range to spray.
Old Feb 16, 2010 | 07:31 AM
Just get you a chilton book and it should have the schematic in it. I used to work for a dealership and I have access to their AllData system.
Old Feb 16, 2010 | 08:36 AM
slowpoke96z28's Avatar
i know a couple people that have a pushbutton along with the other items. basically taking window switches, fuel pressure switches, WOT switches, and then adding a push button. now i dont know anyone not using the other items and only a button, if that is what you are asking.
Old Feb 16, 2010 | 06:00 PM
1904gto's Avatar
ok well thanks for letting me know, appreciate the help
i am drive by wire is therw a diagram into using the WOT switch to arm the button
Old Feb 22, 2010 | 01:15 AM
Trotter's Avatar
just make it all in line with eachother, its simple to do if you've done some electrical work. i had dbw and put my wot switch to activate when the pedal was at wot then had a arming switch and a button to spray.
