Feeding 2 stages
Old Feb 18, 2010 | 01:28 AM
marols7's Avatar
Default Feeding 2 stages
What will the best way to feed my 2 nitrous stages on the fuel side and the nitrous side.
Nitrous
Im using a 10 lb bottle(later will upgrade to a 15 lbs) and have two 4AN main lane and one 6AN.
Option 1) Run the 6an from the bottle(on the trany tunnel) and then use a y fitting to split the 6an into two 4an as closer as I can to the solenoids
Option 2) Use a y fitting on the bottle and run the two 4an since the bottle to each one of their stages
Fuel
Im using a stand alone with a holley black pump and a ragulator, my idea here is to use a y block to spread the main lane(3/8) into two 4an to use the lines that came on the nitrous kit for fuel supply and putting the regulator as closer as I can to the y block to trying to control the pression on the 2 lines after the split
Old Feb 18, 2010 | 01:33 AM
camscam02's Avatar
option #1 on the nitrous side, bigger feed line, less line in the car to deal with, better set up.
Old Feb 21, 2010 | 07:44 PM
SSPerformance's Avatar
run a -6 feed line
