nitrous outlet nitrous plate holding throttle body blade open??
so i just installed a nitrous outlet monoblade plate kit on my 97 lt1 firebird and for some reason now the throttle cable is hold the throttle open a little causing the car to idle at around 2k. seems like the throttle cable isnt long enough to reach the TB cable bracket anymore. you guys have any idea on how to fix this problem?
Guest
Posts: n/a
Did the plate conversion come with the Throttle extension brackets by chance?
Pictured at the bottom on the left next to the plate
http://www.nitrousoutlet.com/catalog...7&product=2808
PM your name so i can look you up in our system.
