Kenne Bell BAP Activation
Old Feb 24, 2010 | 09:47 PM
SkullV's Avatar
Default Kenne Bell BAP Activation
How are you guys activating your Kenne Bell BAPs for nitrous? Are you using the vacuum switch off the manifold or are you using a relay off your arming switch to close the circuit where the vacuum switch should be? Or something else? I really only want the BAP active when I'm spraying so I don't kill the fuel pump.
Thanks!
Old Feb 24, 2010 | 09:59 PM
Beer99C5's Avatar
Mine is wired into my arm switch(s).
The BAP also comes with a vacuum operated switch for wot activation as well (I am not using mine (yet)).
Old Feb 24, 2010 | 10:14 PM
SkullV's Avatar
I'm terrible at reading wiring diagrams, any way you can decipher what is going on between the arming switches and boost-a-pump for me? I am only going to have it activate when the N2O is armed so I don't put any extra strain on the fuel pump (not making enough NA power to need it).
My plan was:
Old Feb 25, 2010 | 09:24 AM
SkullV's Avatar
Anyone know if that will work?
