HSW interface MAF config
Car is a 98 F-Body originally had the 3 wire MAF, I have the TSP 5 wire unit now. My question is what type of sensor is the 5 wire unit supplied with the TSP 100mm unit?
yes sir sure did. TSP said its a 5 wire LS7 unit. I had my second stage noids activating with the arming switch (interface is pulling timming on that stage) it was set for a LS1 MAF and the trigger inputs and outputs were wrong (my fault on that)
