NOS question?
Old Feb 27, 2010 | 09:43 PM
jpeyton1077's Avatar
Default NOS question?
I have a 2004 Z06 with 236/238 601/605 113lsa comp cam, PRC dual valve springs, hardened push rods, and 90mm fast intake with LS2 throttle body. If I put 150 shot to it will it be ok. People i have talk to say its all in the cam. Im new to NOS and just wondering!
Old Feb 27, 2010 | 09:45 PM
camscam02's Avatar
cam doesnt matter until you get up in the higher shots, then it will make a difference
Old Feb 27, 2010 | 09:51 PM
A wide open throttle switch would work good is what i hear. I cant get the tires to stick now with nitto drag radials. If i were to use the traction control with the NOS would it screw it up?
Old Feb 27, 2010 | 10:16 PM
disc0monkey's Avatar
if your thinkin Traction control then i wouldnt get n20 yet because it obliterates the tires easy on a car that hooks well. na man no traction control, it doesn't give anymore traction.
Old Feb 27, 2010 | 10:29 PM
The car was lowered when i bought it. I think alot of my traction problem is that I dont have any travel in my shocks! Should I raise it back up to help with traction?
