Looking for a progressive controller.
Old Mar 5, 2010 | 07:06 AM
Deimos's Avatar
Default Looking for a progressive controller.
I have the MSd 7530T and running a nitrous express shark SX2 dual stage fogger. I don't have a MAP or TPS sensor since I am running a carb. What would be a good controller. I don't need the wideband option since I just bought a FAST wideband. The NOS launcher allows my kit to spray three stages but I really am only concerned about spraying in second and third gear. Any help would be great.
Old Mar 5, 2010 | 08:39 AM
Deimos's Avatar
http://www.holley.com/15977NOS.asp I'm leaning towards this one but I have windows 7 software.
Old Mar 5, 2010 | 08:46 AM
Nitro Dave's Nitrous Outlet's Avatar
There are many options out there. For what you are looking for I think the NOS Mini or FJO mini would be your best option.
NOS mini- Cost 223.50
http://www.nitrousoutlet.com/catalog...0&product=1539
Controlls two stages.
Time base ramp.
Completely water tight sealed case
RPM activation and decactivation
TPS activation (you can turn off)
Time Delay
Gear lock out
Output signals for use with other electronics.
Has a small hand held control unit.
FJO Mini- Cost 206.00
http://www.nitrousoutlet.com/catalog...35&product=952
Time base ramp.
RPM Based Ramp.
Gear lock out
Has to have a laptop for programing.
Old Mar 5, 2010 | 08:47 AM
The launcher is really nice but according to the list of what you are looking for it has a lot of features you are not looking for.
Old Mar 5, 2010 | 08:51 AM
Deimos's Avatar
Can it go off rpm instead of time? Like flow 15 percent up to 100 percent 4000-6500 and then wait a second and flow that again?
Old Mar 5, 2010 | 09:06 AM
Opps I left out both units have window switches...
The NOS mini can not do RPM. The FJO Mini will. Now I beleave the launcher does as well.
I am not sure I would ever use the rpm base ramp unless I was a street racer racing from a roll. The rpm base ramp is only going to make traction issues worse upon tire spin.
Dave
Old Mar 5, 2010 | 09:11 AM
Deimos's Avatar
Does the FJO work with windows 7? What is gear lock out?
Old Mar 5, 2010 | 09:19 AM
3.8redbird's Avatar
OP check out the forsale section there is an FJO for sale by another member for cheaper
Old Mar 5, 2010 | 09:20 AM
streetassasin's Avatar
I have this but havent had a chance to use it yet
http://www.harrisspeedworks.com/prod...age=1&featured
Old Mar 5, 2010 | 09:28 AM
Deimos's Avatar
I saw that in my searches in this section.
Old Mar 5, 2010 | 09:50 AM
Nick@HSW's Avatar
You won't be disappointed...If you'd like to know how it stacks up to the competition just let me know. Thanks.
Nick
Old Mar 5, 2010 | 10:04 AM
Yes it should. I will double check.. Gear lock itallows you to set the controller not to spray until it hits a certain rpm. It counts that tag point as a gear change. So lets say you want it to be third gear before it comes in. You would set it to have to hit that point twice before activation.
Dave
Old Mar 5, 2010 | 07:16 PM
Deimos's Avatar
That would be awesome, I was wondering how it would tell when I went from second to third.
Old Mar 8, 2010 | 10:32 AM
Nick@HSW's Avatar
A neat feature that the MicroEDGE offers, since your main target is gearing, is multi-gear non-linear ramps. This is ideal for situations where different gears require different ramp rates...you could pulse each gear with a different curve to fit your needs. And you can save up to 3 files so you won't need to remember specific settings for various tracks/preparation/days/etc.
Nick
