High idol issue after HSW 78mm palate install...HELP
Old 03-10-2010, 07:03 AM
Deimos's Avatar
You can always use carb spray and spray down the ontake to look for a vaccum leak.
Old 03-10-2010, 07:50 AM
kidcamaro98's Avatar
It does? What does this creature look like?
its a 3" black aluminum bracket that mounts where your throttle cable mount is, then the cable mount, mounts to that.
Old 03-10-2010, 10:07 AM
Nick@HSW's Avatar
Its the little black bracket off to the right in this picture.
Old 03-10-2010, 10:39 AM
bigboykilroy's Avatar
why does it also look like you used teflon tape on the an fitting side as well. you dont need it there take it off if you did.
Also if you are still running the factory PCV system, get rid of the ghetto orange oil filter breather setup you have, you are letting unmeeterd air into your system like that as well.
