Bottle heater
Old Mar 10, 2010 | 07:12 PM
socal gto's Avatar
Default Bottle heater
I am in the process of installing a nitrous outlet bottle heater/bracket and I was wondering if it requires a fuse and if so what size. I just read the instructions and didn't see anything about a fuse.
Old Mar 10, 2010 | 09:49 PM
TS6's Avatar
TS6
Yes, it needs a fuse. Probably 20-25 amp.
Old Mar 10, 2010 | 10:19 PM
socal gto's Avatar
Thanks for the answer.
Old Mar 10, 2010 | 11:59 PM
SkullV's Avatar
I want to say that my HSW heater kit came with a 30 amp inline fuse.
Old Mar 11, 2010 | 07:22 PM
jeepers_88's Avatar
heaters usually pull a fair amount of amps, I have mine running through a relay controlled by the switch. I think the power side of the relay has a 25amp fuse in it.
Old Mar 12, 2010 | 11:11 AM
Nick@HSW's Avatar
Just make sure your fuse doesn't exceed the relay...you want the fuse popping before anything else.
Nick
Old Mar 12, 2010 | 06:34 PM
socal gto's Avatar
i just found the instructions that came with the bracket/heater and I find it wierd that the supplied instructions say to use atleast a 30 amp fuse but when you read the instructions off their site there is nothing about a fuse.
