What to do?
Old Mar 10, 2010 | 08:34 PM
neals98's Avatar
Default What to do?
Ok i am looking at building another motor. What would be the best combo for the money... And that will hold a 300 shot..
ls1 347 stock crank, H beam rods, and forged pistons.
ls1 383 forged bottom end
OR WILL THIS WORK...
5.3 IRON BLOCK bored to a 347 ls1 crank, H beam rods, and forged pistons.
5.3 IRON BLOCK bored and stroked to a 383 forged bottom end..
Old Mar 10, 2010 | 10:37 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Honestly, I am going to move this to the nitrous section just because it seems like that will be the core for your build.
Old Mar 11, 2010 | 07:33 AM
BAKED's Avatar
What happened to your other motor?
With the 383 you will be able to hit it a little harder but any of the options that you listed would work fine if built right...
Old Mar 11, 2010 | 07:48 AM
neals98's Avatar
Broke a rod.. It went 5.91 last weekend on a shitty track. Did not change anything and this past weekend and well here is a vid... I knew it was just a matter of time with all the stock parts in bottom.
http://www.youtube.com/watch?v=kNLGZdMr1Wk
I would really like to stay with the stock cubes for now and just see what it will do hitting it a little harder.. The vid is leaving on a 150 shot..
Old Mar 11, 2010 | 09:15 AM
JL ws-6's Avatar
Race your car!
You could buy my whole motor and probably spend no more $... and if you went 5.9x with a stock internal setup you'll be going a TON faster with this under the hood.
Bigger ci then you're planning, but it's a very solid piece.
Took my 3350 lb car to 9.50 on a 1.4 60 foot, with a way conservative tuneup.
250 hit fogger on this motor will probably put you past what a 10 pt cage is good for if your mustang is in the typical 2700 lb raceweight range.
Old Mar 11, 2010 | 09:47 AM
neals98's Avatar
was that 3350 raceweight or just the car..
