Nitrous help
Old Mar 13, 2010 | 06:12 AM
IWGF's Avatar
Default Nitrous help
Hey guys, I'm going to do a N2O system on my car. I've decided to do a Nitrous Outlet 98-02 F body specific kit. I've still got to get a fuel pump, and most likely injectors. Looks like I will need a bottle heater as well, I have a Tick TPS sensor/WOT sensor that I got for free a while back. Should I stick with that or can someone make another suggestion. Any help would be appreciated guys, I'm a NitroNewb!
Old Mar 13, 2010 | 08:36 AM
PONTIAC SLP's Avatar
let us know about your setup to give you the right way to go with .
Old Mar 13, 2010 | 08:49 AM
IWGF's Avatar
Alrighty. Guess I should have thrown that in the original post.
Stock bottom end
TEA Stg 2.5 5.3 heads (o-ringed)
TSP 228r cam
LS6 intake
Stock trans
MWC 9" w/ full spool and 3.89 gears
Stock fuel system, will be doing an in tank 255lph and injectors
I would like to spray a 150 shot.
Old Mar 14, 2010 | 09:43 AM
with 150HP u will need a 255 fuel pump only if the kit is wet , if u want to be in safe so do a 32 or 36lbs injectors that all what u need .
Old Mar 14, 2010 | 07:42 PM
IWGF's Avatar
Cool. I'm going to do a wet plate kit.
Old Mar 16, 2010 | 12:53 AM
Nitro Dave's Nitrous Outlet's Avatar
Nice system choice.. I would suggest doing a racetronix fuel system. Injectors will only need upgraded if you are maxing them on motor.. We can supply you with the injectors and fuel system as well.
I personally would do our stage 3 accessory package.
It comes with a billet bottle bracket/heater combo, purge, nitrous pressure gauge, fuel pressure safety switch, nitrous filter, nhra fitting and blow down tube.
http://www.nitrousoutlet.com/catalog...3&product=3806
You will need a windowswitch for safety. OUr digital windowswitch has a built in TPS activation and a gear lock out feature to help aid in traction.
http://www.nitrousoutlet.com/catalog...25&product=964
We offer a progressive with the added features of our windowswitch if you would rather go that way.
http://www.nitrousoutlet.com/catalog...3&product=4004
You will need to change your spark plugs to these.. Gap them at .032
http://www.nitrousoutlet.com/catalog...0&product=3469
We have other nice add ons such as a switch panel.
http://www.nitrousoutlet.com/catalog...1&product=2142
Remote bottle opener.
http://www.nitrousoutlet.com/catalog...=23&section=77
Spare tire mounting plate..
http://www.nitrousoutlet.com/catalog...92&product=963
Or a trans tunnel mount.
http://www.nitrousoutlet.com/catalog...22&product=984
Let me know any questions you may have.
Dave
Old Mar 17, 2010 | 12:30 AM
IWGF's Avatar
Thank ya kindly sir. The links are not working though
I have a Tick digital window switch w/ TPS activation and gear lock out, will that be compatible with your system?
I'm aware of the plug switch... My tuner stocks them.
I will need the spare tire mount, as well as a blowdown tube for track use.
Can you PM me a quote for a package deal on this stuff?
For my fuel pump, I'm going to go with a walbro 255lph, in tank. I need to cut the access panel above the tank.
Thanks for your help!
Old Mar 17, 2010 | 01:42 AM
dnkynrbk's Avatar
Just go to nitrousoutlet.com or just call Dave or Chris tom thats the best way and they can get you set up. Plus they will answer your questions.
Old Mar 17, 2010 | 02:36 AM
IWGF's Avatar
I'll probably order through my tuner, he's a dealer for Nitrous Outlet. Just trying to get all the facts straight before I order.
