Smaller cube glide cars
Old Mar 19, 2010 | 07:55 AM
BAKED's Avatar
I'm running 3:90's in mine with the glide.
Keep in mind how high you are going to twist the motor and what kind of trap speeds you want to be able to run.
Old Mar 20, 2010 | 03:41 PM
mikes94z's Avatar
I run a glide. I've left with 300+ off of the brake.
1.80 straight cuts and a 3.89 gear.
Some times you have to look past the 60' times and look at the 330' times to see the true benifits.
Old Mar 21, 2010 | 02:03 AM
w3s1c0a5t's Avatar
For sure. Before i Change the rear gear i have to really figure out the motor setup. Looking like i might go carb.
Old Mar 22, 2010 | 12:47 PM
massillongoat's Avatar
Originally Posted by w3s1c0a5t
Hell ya. It's got 3.55's so that's will be run for at least a bit. Till I decide how much gear I actually want.
I plan on a 150 pill right off the brake
u can say that again
Old Mar 23, 2010 | 01:51 AM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Originally Posted by SMITH
I had a glide in my car when I was stock cube. It had a 1.8 first gear with an 8 inch converter.
How much slip were you seeing with the 8 inch converter? I am wondering what the limits of an 8 inch setup are?
Old Mar 25, 2010 | 03:17 PM
w3s1c0a5t's Avatar
Is a 9.5 converter going to work with my setup? 3000-3100 pounds ladder bars probably 3.90 gear.
Havent really figured out what im going to do with motor. Probably a holley 750 super vic worked 241's 150 shot. But who knows havent really got it all figured out on that part
