Smaller cube glide cars
Old Mar 14, 2010 | 03:50 AM
w3s1c0a5t's Avatar
Default Smaller cube glide cars
What made you guys go glide? How many of you are still doing power management or can you launch 100% power.
Curious because I been getting a lot of **** over going glide. Wondering why/how it has/is working for you guys
Old Mar 14, 2010 | 06:40 AM
ls1psycho's Avatar
whats your car weigh, what kind of power are you making? the gear ratio in the glide usually helps high horsepower cars that fight traction issues.
Old Mar 14, 2010 | 08:40 AM
BAKED's Avatar
I still can't launch 100% but I'm spraying a pretty good sized shot.
The glide will absolutely kill your N/A times if you are running a tight converter.
If you ave a car that weighs in the 3200lb or less range and it makes over 600rwhp then you might benefit from it. if not the stick with a TH350 or 400
Old Mar 14, 2010 | 11:51 AM
w3s1c0a5t's Avatar
Should be pretty light. Was 3345 full weight with spare and c5z motorsports.
Hoping to get it less than 3100 raceweight. Will be a big cam lq9 with about 10.5:1 and a 200 shot eventually once the tuneups in hand.
Wanting to get into the 9's. What gear/tire size combo are you guys running?
Old Mar 16, 2010 | 06:39 PM
Firehawk441's Avatar
Stick with a 3 speed.
Old Mar 16, 2010 | 09:36 PM
w3s1c0a5t's Avatar
Well to be completely honest. I had a 4l60e i straight swapped a guy for a good glide. Brake turbo input 9' converter etc. Too good a deal. Before I did it i took a look at Baked shiz atv and some of the stock cube guys and most of them run a glide so i figured that was the direction i needed to go anyway. So i pretty much jumped on the PG band wagon like that.
Hoping I can make it all work now.
Old Mar 16, 2010 | 10:15 PM
ATVracr's Avatar
It will work, its all in the converter.
Old Mar 16, 2010 | 10:28 PM
w3s1c0a5t's Avatar
Thats what the guys who run hard all seem to say.
Im trying to figure out who made the 9' i have know. Once i get some specs on it i think im going to let fti or someone go over it.
How important have you found rear gear to be?
Old Mar 17, 2010 | 07:00 AM
lca1971's Avatar
[QUOTE=ATVracr;13043816]It will work, its all in the converter.[/QUOTE
This is all you need to know!! Run a straight cut 1.76 and find a converter company that have small tire cars in their stable. Bradco, PTC, Ultimate converter concept, to name a few.
Old Mar 17, 2010 | 07:34 AM
Noyzee's Avatar
8 second mod
call marty at neal chance, he can set you up and make it work
Old Mar 17, 2010 | 08:59 AM
ATVracr's Avatar
PTC is what we have in the car now.
Works good!
Old Mar 17, 2010 | 05:56 PM
SMITH's Avatar
I had a glide in my car when I was stock cube. It had a 1.8 first gear with an 8 inch converter.
Old Mar 17, 2010 | 07:57 PM
w3s1c0a5t's Avatar
^ how did it do? What would you have done different?
Old Mar 17, 2010 | 08:14 PM
ATVracr's Avatar
Pretty sure he still has the record for 347 on nitrous.
So I guess it did good. LOL
Old Mar 18, 2010 | 11:36 AM
w3s1c0a5t's Avatar
Well that's silly... Well then....
On the glides are you guys running as much gear as you can?
Some other opinions I got made it seem like if you didn't have 4.56's it wouldn move off the line even with the brake
Old Mar 18, 2010 | 12:52 PM
ATVracr's Avatar
Spray it out of the hole and it will move!
Yes, as much gear as you can helps.
We run 4.10's
Old Mar 18, 2010 | 06:21 PM
SMITH's Avatar
It done ok.
I had a 3.90 gear in it.
Old Mar 18, 2010 | 06:25 PM
camscam02's Avatar
Originally Posted by SMITH
It done ok.
YALL slow!
Old Mar 18, 2010 | 06:48 PM
w3s1c0a5t's Avatar
Hell ya. It's got 3.55's so that's will be run for at least a bit. Till I decide how much gear I actually want.
I plan on a 150 pill right off the brake
Old Mar 18, 2010 | 08:38 PM
w3s1c0a5t's Avatar
