harris speedworks nitrous kit
Old Mar 23, 2010 | 10:28 PM
camscam02's Avatar
The reason you are stepping up jet sizes is you are seeing it go lean early, say from 4-5200 or so and then go to where it should be afr wise, and you are trying to fix the early part. Which you dont need to, you should worry where you are most of the time when WOT say 5600-6500 or so, because on a wot nitrous pass you wont touch that early section, thats ofcourse what I think you guys are doing wrong.
In the realm of things for example a 62N jet and a 35F jet at 60psi is pretty rich, if you would look at the plugs you would see this. I have messed with a good number of these cars with plates in the regions you guys are talking and not one have I had to go up on the fuel jet.
Old Mar 24, 2010 | 09:03 AM
ScreaminRedZ's Avatar
registered user
Originally Posted by Nick@HSW
Or just stay on the line and as soon as someone is free they'll grab it.
Nick
That's what I'm saying. I do stay on the line and talk to a real person. They always listen to my question and then say, "what you want to do is go to our website and punch a trouble ticket there..."
Rather just do the tech thing on here through PM's if the phone isn't an option
If you spray it off the line you will definitely hit that lower rpm. I'd rather have it slightly rich up top and safe down low rather than lean under 5000 rpm and right on par up top.
Old Mar 24, 2010 | 10:15 AM
Nick@HSW's Avatar
Just shoot me a PM if that's what you'd like...
Old Mar 24, 2010 | 01:55 PM
registered user
Appreciate it! I gotta get this thing all squared away so I can get some more track and street videos
Old Mar 24, 2010 | 01:56 PM
camscam02's Avatar
Have you ever logged a pass and seen what rpms you are in going down the track? Guaranteed you are in the 5000+ rpm range over 90% of the time and you want the best power and best tuneup there. Having it slightly lean for .5-.75 of a second when the motor has no heat in it, is not gonna do anything, compared to it being rather rich for 9 seconds going down the track.
But do as you wish. Remember you reading an average afr and on a dyno. My opinion ofcourse.
Old Mar 24, 2010 | 04:52 PM
registered user
What's a good range? What starts getting too lean and what starts getting too rich? What's a normal change throughout a run?
I know that my air/fuel was hitting 13's in the mid range last time I was on the dyno and a sponsor on this site told me that I should have aborted the run when he saw the graph.
I've also seen other people post up graphs where the air/fuel jumps over 14 for a short time before dropping to normal and no one says anything about it.
How high is it safe to get with that initial spike?
I'm just trying to learn without blowing my stuff up, so any advice/knowledge I'm given is much appreciated!
Old Mar 24, 2010 | 10:54 PM
1qwkz's Avatar
Originally Posted by itsslow98
Definetly a good idea, I had to step up 5 jet sizes on 100 shot to get the a/f right. Wound up with a .033 instead of the .028.
yea i ended up with the 031 fuel jet for the 100 shot of spray. made 402 motor and 500 on 100 pill!
Old Mar 24, 2010 | 11:16 PM
Frozen WS6's Avatar
Yes Harris is one of the best nitrous kits available for our cars both in quality of parts and customer service. #1 in my book as well as many others. You will not be disappointed one bit.
They are very popular company and their kits are awesome.
Nick at Harris helped me out a bunch.
Old Mar 24, 2010 | 11:33 PM
camscam02's Avatar
You want to shoot for the best tuneup in the range that you will be running in mostly. So for nitrous it will be WOT and usually within a 1000 rpms of redline or so in general. Yes you launch and depending on launch it may be in the high 3000-4000 range for a split second but id concentrate on the 5000+ range.
Your lean spikes may also be due to the nitrous getting there a lot quicker then the fuel at the hit, 900psi compared to 60 psi that 900 will get there before. so that could be something to think about as well.
Its hard to say what safe is really, but if hits 13's for a split second and comes down into the 12's then that is a heck of a lot better then 12's for a split second going down in the 10's. And then again we are trusting an AFR on a dyno which doesn't correctly demonstrate what the motor will be doing say on a wot blast through the gears or a track pass, there will be alot more heat with a 10-11 second pass compared to a 4-5 second dyno pull.
This is just my thinking and what I do/think. We dont tune on a dyno and we know where our baselines should be and go from there.
Ok rant over.
Old Mar 24, 2010 | 11:38 PM
itsslow98's Avatar
Any experience with the Innovate logworks program?, I have the XD-16 sitting in the trunk waiting for an install and have no idea what to expect from there program. Will this give me an accurate chart/log of my a/f or is it too basic. The XD-16 has datalogging capabilites with the software.
Old Mar 24, 2010 | 11:45 PM
camscam02's Avatar
I have an innovate lm1 but dont use their software, I have it hooked to my hptuners. But I have looked at it and pretty sure just the regular logging just logs an afr per given time, you would have to get an rpm converter to be able to log afr vs rpm as far as I know. Thats just an educated guess though.
Old Mar 24, 2010 | 11:50 PM
  #32
itsslow98's Avatar
thanks, dont have the cash for HP tuners so ill give there software a shot just for datalogging.
Old Mar 25, 2010 | 07:18 AM
  #33
registered user
If a properly working system would drop from the 13's into the 12's then why would one that starts in the 12's drop into the 10's?
Is that initial lean spike that alot of people see safe to have or if not, is there a way to get rid of it? I figure, if it's due to the nitrous getting there first, then it's not RPM based and will happen at any RPM, like say a street pull that starts in 2nd gear at 5000 rpm.
Also, I know that some of people say that reading the plugs is better than an air/fuel meter. My question about that is, if the engine is running lean in the lower RPM, and then right on in the higher RPM and you do a full pass and then shut it down and check the plugs, will the fact that it was lean earlier show up on the plugs or no because the last thing the motor saw was the proper air/fuel before it was shut off?
Not trying to argue or give anyone a hard time, just asking serious questions that I have as I learn more about nitrous systems and how they work.
Old Mar 25, 2010 | 10:14 AM
  #34
Nick@HSW's Avatar
I think you're really over analyzing things. Unfortunately dropping bottle pressure is just the nature of the beast (unless you step up into a nano system). There's things you can do to curb the issues associated but we're shooting blindly here because we still don't know what's going on with other systems in the car. And until we do, you can ask a million times and you'll never get the same answer because it could be a million things with the car, or none at all. Heck it could be as dumb as an exhaust leak or too much timing or not enough pump. And just because you think something might not be an issue, there could be a collapsed hose, blockage, etc. So like I said earlier shoot me a PM once you have everything logged and lets take a giant step to diagnostics rather than ten million little steps in circles.
Nick
Old Mar 25, 2010 | 11:30 AM
  #35
registered user
I wasn't referring to my car. camscam02 was talking to the people who said they had to run richer jets than listed and that's where the line of questions originated from. As for the initial lean spike, mine isn't a spike. I was referring to the graphs I've seen in general where they spike lean and then level out to a good range.
As for my specific car, I realize that there is an actual problem. I'm not saying what's causing the problem and I'm not saying that there is anything wrong with the kit. It was working fine for a year and then something happened, meaning that it's not a defect in the kit or anything like that.
I'll stop asking questions as I'm really not looking to cause problems or upset anyone.
Old Mar 25, 2010 | 01:35 PM
  #36
camscam02's Avatar
Just remember we are talking in general here, every case may be different and Im stating all cases as one. the fuel line as short as possible would help with the spike, purging the kit before hand to make sure there is fuel at the solenoid will help.
A little lean spike is not one id ever be worried about, it will happen for maybe a second and that will not hurt anything. Lean doesnt even hurt parts most of the time unless there is too much timing in the motor as well.
I think people are adding fuel because they think it is lean in spots and in fact they are making the right part rich. Sometimes it may be needed but most of the time from my experiences I would say no.
remember no question is a dumb question but if you keep questioning the answer then most will just say to the hell with it
