an ls1 stocker with n20 jetting question
the nozzle is not mounted yet. i thought it had to go behind the maf?
125 on a stock bottom end is perfectly fine. The fuel pump should be able to keep up but for safety I would put a walbro 255 in it if you want to. run a ngk br6ef plug stock number 3177.
I would pull a couple of degrees for safety but you might be able to get away with it.
I smell nitrous newbs and cheap HP goals(neither is bad but please do research so your not in here next week asking why the motor blew)
While nitrous is a relatively cheap source of HP, don't just buy a $200 kit and think you'll be fine. Get quality parts, including a timing controller, and you should be fine with a 125 hit.
Good luck.
