Nitrous and relocating battery?
i dont want to run the nitrous on the hump in the back seat. i cant put the battery where the cd changer is at, because im putting a sub there. i dont want to put the battery in the t-top holder area either.
my question is, is anyone running a 10 lb bottle and a battery in that area? if not then any ideas where i can put the battery?
do you think youre gonna be able to keep the hatch speaker there? i dont really mind taking it out, but i would prefer to leave it be.and i saw their turbo thread and i plan on picking that up eventually, if it turns out to be as good as it sounds.
I mounted the bottle using the cheap bottle brackets that came with my NOS-5177 and built the battery tray out of angle iron and all thread. I put the brackets close enough together so I can also swap in a 10lb bottle if need be. I'll try to get some pics tonight if I remember.
FWIW, I used a lightweight battery (PC680) in the stock location for about a year. It worked for about a year, but I never felt comfortable using my bottle warmer without the car running. Even with my wife starting the car every two weeks, the PC680 still died about half way through my tour in Iraq and just wouldn't take a charge at all anymore. I'm definatley glad to be back on a full sized battery myself.
the more pictures the better though
See, I initially (like 8 years ago) mounted the bottle at a low enough angle and still retained the speaker. Then, the speakers came out for weight reduction about three years ago. Now, about a year ago, I wanted to put a full size battery back there two, which caused me to stand the bottle up a little more to make room for the battery.
Cover installed......
And removed........
Here's why the speaker would have to be removed with a 15lb bottle. Again though....gives a rear seat passenger easy access to the bottle valve. Just pop off he grill and there it is
And here's how tight it is between the battery tray and bottle. I'm sure a minor redesign could fix this......but it works fine for me. Bottle goes in and out with no issues.
Hope this helps.
GC99TA: Very interesting pictures! I've been wanting some pictures of guys who mounted their bottle and battery back there for a while. I have yet to come up with any until now. Nice work.
Dave
