water meth/ Nitrous spray bar
would probably work, but you would have to check flow rate , and ensure you are getting good atomisation / misting with the plate.
also it is best to have meth spray upstream of the Intake Temp sensor so PCM can read temp changes when your spraying.
and if the plate is after the TB a check valve will be required to prevent meth siphoning under manifold vaccume.
