View Poll Results: which of these will work good with nitrous?
MS4
3
33.33%
MS3
6
66.67%
Voters: 9. You may not vote on this poll
Nitrous Cams
Old Apr 20, 2010 | 12:36 AM
eminem1833's Avatar
Default Nitrous Cams
which of these cams will work better with nitrous?
MS4 or MS3 ?
what LSA it should be?
any other nitrous cam?
thanks
Old Apr 20, 2010 | 01:13 AM
itsslow98's Avatar
from what ive read and been told cams dont really start affecting nitrous until your spraying over 175 shot so just about any of the regular proven cams and such will work great and have no ill effects due to nitrous.
BTW what shot are you looking to run and what are your goals.
Old Apr 20, 2010 | 01:16 AM
eminem1833's Avatar
about 175 - 200 shoots
Old Apr 20, 2010 | 01:19 AM
itsslow98's Avatar
i wouldnt think too much into it but ill let the experts chime in with what they think.
Old Apr 20, 2010 | 02:00 AM
eminem1833's Avatar
thanks bro
i will wait you
Old Apr 21, 2010 | 02:59 PM
dnkynrbk's Avatar
MS3 cam I had in my old set up and screamed. I have always heard the ms3 cam was alot better of a cam then the ms4. My old set up went a 10.14 on a 150 shot 370ci with patriot heads stage 3 with a 4l60e tranny 3500 stall. Car ran 11.07 on NA. with that cam.
Old Apr 22, 2010 | 02:50 AM
eminem1833's Avatar
sounds good
MS3 +++++++++++++++++
thanks
Old Apr 22, 2010 | 07:17 AM
BAKED's Avatar
Out of those choices I would go with the MS3.
Old Apr 22, 2010 | 08:29 AM
Noyzee's Avatar
8 second mod
what are the specs on each cam?
Old Apr 22, 2010 | 03:11 PM
00pewtertransam's Avatar
603/609 237/242 111 ms3
649/609 239/242 111 ms4
i had the ms4 in my stock bottom end ls1 with stock 243 heads and sprayed a 100 shot and went 11.4 my first pass ever. never got to spray it down the track again with that set up and a stick car. if i remember correctly thats was a 1.7 sixty foot. i loved my ms4. it pulled like a freight train in 3rd and 4th gears and i walked my buddy that had the ms3.
Old Apr 23, 2010 | 09:32 AM
Noyzee's Avatar
8 second mod
not a fan of either one for stock motor. i would go with the bigger spread if i had to pick. 237.242 just to try to bleed some heat off stock pistions. but these cams make peak power but not sure how they will work with a motor only runng 6200 6500 rpm. probably not huge low end power.
Old Apr 23, 2010 | 10:30 AM
yeah they are both a little healthy for stock motor. when i ran the ms4 i had a 4.33 gear in my 9in to help with the cam. i loved it though. it just pulled so hard up top. i was twisting my motor around 6700 with it. to help keep in powerband. i never sprayed it on the dyno either so not sure how it did really responded to nitrous. but on the street and the one time i hit the nitrous at the track it freaked out.
Old Apr 23, 2010 | 10:44 AM
Noyzee's Avatar
8 second mod
yea, if you gear and converter around it, it will work, but his looks like its already set up and these wont work as well.
Old Apr 23, 2010 | 11:52 AM
Chris@NitroDaves
Guest
Posts: n/a
Old Apr 24, 2010 | 08:46 AM
02 BLK WS6's Avatar
I didn't vote, but I'll offer my .02 - Custom grind for your setup. I'm not a fan of aggressive ramp rates and more than .600 lift on a street car.
