what does a NANO system actually do
Old Apr 28, 2010 | 09:53 PM
WALK NASTY984's Avatar
Default what does a NANO system actually do
just curious at what these nano systems actually do
Old Apr 28, 2010 | 11:12 PM
itsslow98's Avatar
go to there website it will tell you everything u wanna know
Old Apr 29, 2010 | 01:18 AM
BobDoLe's Avatar
put simply, it is a push system that pushes air into the nitrous bottle to keep the nitrous pressure up.
Old Apr 29, 2010 | 12:03 PM
Vindicated346's Avatar
like bobdole said, it maintains contsant pressure by filling the empty space of the bottle with air as you spray, kinda think of it like a caulking gun..thats the easiest way i can explain it
Old Apr 30, 2010 | 01:31 AM
LilJayV10's Avatar
Doesn't it use nitrogen and not "air"?
I guess they chose nitrogen for a reason, whatever that reason is I don't know, but would like too.
Old Apr 30, 2010 | 04:06 AM
rice4eatingnotdrivin's Avatar
yeah its nitrogen not air
Old May 1, 2010 | 03:40 PM
DiabloFormula's Avatar
You can use nitrogen or air, I use air in mine, just a hint of advice, don't go crazy on purging with NANO, it emptys much faster then without.
Old May 1, 2010 | 03:48 PM
choopak's Avatar
Yup, when i purge it goes like 10ft in the air............
Nano set up is probably the best thing that has come to nitrous in years
 Michael S. Palmer
Old May 1, 2010 | 10:15 PM
SpeedSlut's Avatar
The air we breath is almost 80% nitrogen at sea also nitrogen is more consistent because it dosent expand nearly as much with temp as just regular "air"
Old May 3, 2010 | 01:34 PM
AutomagicLS1's Avatar
Basically if you make a motor pull and say you make 401 on motor then ya make a nitrous pull (100 shot) you will see 501 give or take a few horse power from soon as you start squirting till when you shut it down. The power will never fall off since it has something keeping the pressure constant (nano). The nice thing about nano is you can make back to back pulls / dyno, street, track and the shot will always stay the same since you don't have to worry about bottle pressure dropping off. If you get nano call or PM Brad about jetting. It's a little different
Old May 4, 2010 | 07:32 AM
BAKED's Avatar
Pusher systems have been around for a long time. NANO just marketed theirs better than the other companies LOL.
Old May 4, 2010 | 01:12 PM
jmill96Z's Avatar
Because nitrogen is an inert gas, whereas "air" still carries oxygen content.
Old May 4, 2010 | 02:36 PM
LilJayV10's Avatar
That makes sense. I never knew why they used nitrogen. I am officially smarter today.
Old May 4, 2010 | 02:41 PM
KeithBerryZ06's Avatar
Why use it? If pressure drop or loss of product flow is your concern go to a bigger bottle. I'm assuming your using this at the drag strip. I haven't personally used it but I race with most of the top dogs in the country on nos and have spoke to them about it and none of them recommend it and yes some have tried it. I spray 600 plus off the transbrake on a 15 lb bottle in the 1/8 and 1/4. We datalog the nitrous pressure the entire run and weigh our bottles before and after each pass. Spend your money on the bigger bottle. That being said I'm sure some guys here have it and love it and that's all good but trust me when I tell you that if it was an advantage you would see it on all the heavy hitters cars in drag racing but you don't. Good luck on which ever way you decide.
Old May 4, 2010 | 03:17 PM
jmill96Z's Avatar
Damn keith, didn't know you were gettin down with 6 hundo.
Old May 4, 2010 | 03:39 PM
kinglt-1's Avatar
I understand what your saying, but nano has its place. Even if you go to a bigger bottle the nano system will still let you use up most of the bottle while maintaining consistent pressure. With out it your limited to about half of a bottle before the pressure starts dropping. To each is own I guess...
Old May 4, 2010 | 03:47 PM
ryarbrough's Avatar
Not having the NANO also allows some of us a little safety margin. For example, the tuneup in my car is pretty aggressive. As I get down to the top end of the track, the loss of pressure richens the kit up some, making the tune up a little closer to "normal" logic while allowing me to be very aggressive with jetting down low (to the eighth). Just another thought
Old May 4, 2010 | 03:49 PM
camscam02's Avatar
All big nitrous racers, change bottles every pass anyways and usually have a good amount with them so that is not needed for them either. They also usually have a water box for heat and that works very easily to keep pressure constant while waiting to go in the car.
They are more oriented to the ordinary weekend racer or street guy where there is less to worry about and usually only have one bottle with them. But I know of racers usually them and liking them. Although pusher systems are mostly outlawed in most heads up classes.
Thanks for the tech info Kieth.
We recently received a NANO kit and will be testing its ins and outs on my car. It will be a great tech article on your ordinary nitrous small shot lsx car. Look for it in the upcoming months.
Old May 4, 2010 | 03:50 PM
camscam02's Avatar
I didnt know they had that much on the car either. But it sure scoots for having IRS. And sooounds damn good.
Old May 4, 2010 | 08:04 PM
kinglt-1's Avatar
I dont agree with that logic, but if it works for ya, why change...
