Good system or bad?
Old Apr 29, 2010 | 12:42 PM
09jyounger's Avatar
Default Good system or bad?
I've decided to look into nitrous for my 96 camaro. I'm new to nitrous, so I'm looking for something that would be a good starter kit. Mods on my car are: forged eagle 383 rotating assembly (about 11:1 comp), arp bolt kit, 230/236 cam with all supporting mods, #30 svo injectors, bbk fuel pump, and a the regular bolt ons plus a dyno tune. I found this zex kit and it looks pretty appealing due to its "active fuel management system". My questions are: 1. Is this a RELIABLE and SAFE kit to use? 2. What would be a safe shot to use on my car? 3. Would a tune with nitrous be necessary for my setup?
http://www.lmperformance.com/16473/2.html
All help is appreciated
Old Apr 30, 2010 | 09:25 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
sounds like you have a nice setup going.
The ZEX system cannot activley monitor A/F ratio as it does not have any way to measure it ...is it a bad system... no
My questions are:
this will depend on the effort you put into the install and tuning
this will depend on how the engine is built, you can run 150 safely on a stock motor, a forged rotating assembly with the proper ring gap and tuning can run alot more than that.
YES....
BTW for just a little more ($699) we offer a plate system for the LT1 that can support everything you would want to do with your car.
We also have a single nozzle system, like the ZEX kit for $349...or the Nitrous Outlet single nozzle with higher flowing solenoids for $499. These leave you extra money to buy the accessories to make the kit safer and perform better.
Please let me know if you need any more help,
Ray
