E3 plugs? Go or no go for NO2?
Old May 5, 2010 | 12:26 PM
t72ss402's Avatar
Default E3 plugs? Go or no go for NO2?
Has anyone sprayed on E3 plugs yet? Are they able to take about 100 shot?
Old May 5, 2010 | 12:48 PM
ryarbrough's Avatar
Don't use them... Get a set of BR6EF plugs if you plan to stick with the 100 shot. If you are going up from there, use a BR7EF until about 200.
Old May 5, 2010 | 01:16 PM
1lejohn's Avatar
Yea the E3's are not good for N2O. They are basically a stock heat range plug.
Old May 6, 2010 | 06:48 AM
t72ss402's Avatar
Ok thanks guys. I do have some E3 that I just put in the car to see if they really do add any horsepower. I will be going to the track friday. Before I ran a 12.45 @ 111 on a stock LS6/4L80E w/ 12bolt and 3.42 gears. Just curious if all the hipe is true about these plugs.
Next step will probably be a nos set up. I have not decideded on which brand yet, will worry about that when that time comes.
Old May 6, 2010 | 08:50 AM
ryarbrough's Avatar
It's not going to add any power. It's all a marketing gimic.
Old May 6, 2010 | 09:27 AM
Nick@HSW's Avatar
Yea you'll definitely want to get rid of them before spraying.
Nick
