No2 Setup?
Old May 13, 2010 | 02:22 PM
BFarrier's Avatar
Default No2 Setup?
KIf i run 150hp shot of No2 is there an engine setup combination i have to run so i dont get any detonation? like back timing off and/or change spark plugs?.. im open to suggestion too im going to be using the stock 2000 ls1 cam shaft since the exhaust duration is more than the intake duration...
Old May 13, 2010 | 02:52 PM
99BlackTransAm's Avatar
stickys have alot of good info, id say run a -2 colder plug and back off timing 2* for every 50hp of nitrous you are runing
Old May 13, 2010 | 03:22 PM
dnkynrbk's Avatar
150 shot I would go with a #7 plug non proj and back the timming off like above
Old May 13, 2010 | 04:37 PM
BFarrier's Avatar
so i would back off the timing 6 degrees you guys are saying for a 150hp shot
