Who swaps there plugs when they are going to shoot?
On my new build i am going with trick flow as cast 220 heads and my f13 cam. Trick flow recommends the NGK TR6 spark plug with their heads which is what i would run if i was only running NA. I also have a direct port 250 shot on top of my fast 90 intake. While shooting i would think it be wise to run a 8 heat range non projected plug.
Should i run the TR6 on the street and the other plugs at the track or should i just run some BR7EF plugs gapped to .035 and just call it a day?
joe
joe
well the br7 is the coldest non projector resistor plug that i can find. Non of you guys see problems with running non-resistor plugs when at the track?
