Toggle switch wiring question
Old Jun 4, 2010 | 12:02 AM
wdw1979lt1's Avatar
Default Toggle switch wiring question
I was wondering if you can wire 2 stages of nitrous and a standalone to the same toggle switch, so that one toggle arms them all. I have a relay for each stage and a relay for the standalone. Thanks
Old Jun 4, 2010 | 04:58 AM
xXxSilveradoxXx's Avatar
Yeah, that shouldn't be a problem. Just solder two wires onto your switched 12V wire and run one to pin 85 on each of the three solenoids.
Old Jun 4, 2010 | 03:07 PM
Chris@NitroDaves
Guest
Posts: n/a
As stated above you should be able to do that without a problem.
