Nitrous on a stock crank
SDB
I have some TEA 2.08/1.60 6.0 Heads on the way, i have a stock 6.0 shortblock sitting here, and im in the process of trying to decide what pistons/rods/crank to use.
I was going to use Diamond Pistons, Eagle Rods w/ARP's, and an Eagle Crank.
I will probably spray 300 to it, what do you guys think.
I think the weight issue isn't really an issue, since most of the weight variances has alot to do with how much bobweight had to be removed to balance the assembly.
Also, if there is any hard proof that there is a measurable (and consistant) weight difference, with the LS1's being lighter, it's because the main journals are hollow, so you're talking about a miniscule amount of mass, that's only in the very center of the pivot point. It would make more of a difference if the weight was out on the ends of the bobs or the rod journals, but being at the very center of the rotation, the parasitic effects are negligable.
I personally think the additional material in the center of the main journals makes it that much stronger, and you don't have the stress points of a 90* angle either.
Just my $.02
