Nitrous Outlet, come here!
The kit i have on the car is a Nitrous Express universal wet kit. When i first dyno'd the car on a 150 shot it laid down 495rwhp/549rwtq with a .62N .33F like their chart says.
Now just a couple months ago i slapped on the Nitrous Outlet 78mm plate and used that chart which says .62N .38F for a 150 shot. I was disappointed with the numbers (on the hp side) to be honest. Laid down 455rwhp/587rwtq but i'm sure the hp numbers were down due to not enough nitrous for all that fuel being added from that .38 jet on the fuel side, it was PIG RICH! Put the .33 back in and it runs like a champ.
All i want to do is add a little bit more, like a 175 shot. To me a .67N .36-.38F jet seems about right. But if what camscam02 is getting at is right then maybe a .73N is needed to flow enough through the plate to get 175rwhp.
When the airfuel is dialed in correctly the system will make the power.
Here are plenty of our customers that prove the point.
http://www.nitrousoutlet.com/videos/index.asp
Since you had a NX system look at there single nozzle jetting for 175 and 200 hp.. Its the same suggested nitrous jet as what we suggest for our plate. A properly designed nozzle with one flow passage is about as less of a restriction as you are going to get other than flowing just a jet only. There nozzle is a great flowing nozzle and by far has been on the market for many years.
We flow test our products and we also dyno test them. Our product is rated at the rear wheel. We are taking into concideration drivetrain loss as well. By seting up the jetting this way there are alot of variables that come into play. That is why results may in many cases vary from 10 hp or so either which way.
We have seen different cars have completely different results with the same system and same jetting. I have seen cars make spec on the power. Some cars make alittle under and some make way over.. All depended on the car.
Another thing to concider... There are alot of varibles that come into play when determaining flowing horsepower.
Jets can be machined differently. One jet marked .062 may be completely different when spec to another brand jet marked .062.
Different size solenoids, different hoses, different bottle valves etc can alter flow rates.. There are alot of varibles.
Nothing is writen into stone.. Its all just a suggested starting point to tune your system in at. Adjust the fuel jet to the airfuel target and adjust the nitrous jet to the horse power level you are looking to achieve.
Dave
Would the .125 from NO be a direct replacement for what i have now? (4AN line to the solenoid, 3AN line to the plate, and purge port on the side of the solenoid)
Dave
