sponsers step in
http://nitrousexpress.com/product-details.php?id=202
Wont find any better solenoids. Period.
I would suggest going with the Nitrous Outlet nitrous and fuel solenoids as they give you potential upgrade room down the road.
give us a call at the shop if you have any more questions.
Their isnt a another solenoid that looks as good or has the reliability of the NX lightning series. The built in purge port allows for super clean install as well. No need for adapters.
Nitrous outlet solenoids are an ok option as well.Their Highend solenoid is very similar to our old Iceman solenoids that we use to use before we developed the lightning series.
Let Me know when your ready and we can get them out same day. If you would like you can email this too me at Graham@nitrousexpress.com
http://www.nitrousexpress.com/orderform
and I will handle the order and get you all wrapped up sir.
If you were looking at our noids then i'd suggest these
N20 - http://www.nitrousoutlet.com/catalog...4&product=2193
Fuel - http://www.nitrousoutlet.com/catalog...4&product=2194
As many people know Nitrous Outlet was a re seller of many of the other named nitrous companies before going into manufacturing. Over the years we have had the pleasure of using, installing and testing just about every solenoid design on the market.
We started designing our entire product line based around what we liked and disliked about all the other nitrous companies.
We spent a great deal of money finalizing our current solenoid design.
Since Graham has chosen to talk up the NX lightning solenoid by talking down our product by comparison I feel the need to respond with my opnion on his statement. I will say that the old style NX iceman solenoid was a nice design, however it is not the exact same as the current Nitrous Outlet solenoids. It does have similiarities as I personaly felt that was the best solenoid design ever offered on the market unit we made a few tweeks and created our current design. As a matter of Fact, other than our current Nitrous Outlet solenoid the Old style NX Iceman solenoids are the only other solenoids I would use on my personal motor. (with a fuel piston change)
Our current design is built the way they are for a reason.
Our Nitrous Solenoid can reliably support up to 500 HP and only cost 99.99
The Nitrous Solenoid has a .125 orfice.
It uses the purge port design which allows you to purge liquid nitrous all the way up into the base of the solenoid.
It has a stainless machined base which for better magnetics and preventing corrosion and striping of threads.
It also has a stainless coil cap for stronger magnetics.
25amp epoxy encapsulated coils with 14 gauge wire.
Filter screen in pressure port.
Made In The USA!
The fuel solenoid is designed to work with todays fuels. It is a .187 orfice and only cost 79.99
It also uses a bottom exit design as well as the stainless base and steel can.
5amp epoxy encapsulated coil with 14 gauge wire.
Filter screen in the pressure port.
Made In The USA!
Our solenoids are stamped with the Nitrous Outlet logo for easy identification. Our solenoids are designed to take years of abuse from a progressive controller and we also offer a limited lifetime warrenty which I believe has become pretty much industry standard.
While there are plenty of solenoid designs and brands on the market I personaly choose the design build of our current solenoids for a reason and there is nothing I would change about them if I had to do it all over again.
Let me know if I can help you with any questions you may have.
Dave
PS. I think a customers personal picture of our product on his pride and joy speaks for itself.
