seem lean 13.1 A/f
Old Jul 1, 2010 | 08:03 PM
Dragman's Avatar
U are about same as me I run 150 shot. I have had NOS filter clogged up alittle and mess with AF. I can usually tell because purge sounds different. I also think u are way to rich N/A get it up to at least 12.8 - 12.9 N/A. I run NOS at -6 degree's timing and have 11.8 - 12 AFR with NOS.
Old Jul 1, 2010 | 08:30 PM
jman54002's Avatar
which filter are you plugging the one on the solenoid?" screen" or do you have a inline one.
Old Jul 1, 2010 | 08:43 PM
Dragman's Avatar
NOS inlet solenoid screen!
Old Jul 1, 2010 | 08:45 PM
jman54002's Avatar
Crap....forgot about that dam thing....got check it thanks for the remind.
Old Jul 1, 2010 | 09:37 PM
Dragman's Avatar
let us know what u find.
Old Jul 7, 2010 | 12:20 PM
jman54002's Avatar
Default update
I checked the filter and it was clean as it can be....So not sure what the problem is. When I put the NOS plate back on it works fine. I also checked the Nirtous Outlet plate and it looks fine also. So not sure what the problem is yet.
By Brett Foote | 2026-06-04 05:00:17
