Nitrous Oxide and tuning?
Old Jul 9, 2010 | 04:08 PM
senicalj4579's Avatar
Default Nitrous Oxide and tuning?
Been thinking about nitrous after a stall for my auto. But I was wondering how the tune is gonna be for nitrous. When you get a tune for nitrous does that mean when your not using the nitrous the tune is gonna suck because the computer is no longer tuned for stock?
Old Jul 9, 2010 | 05:02 PM
a4ls2goat's Avatar
you can make a in between tune
Old Jul 9, 2010 | 05:40 PM
Chris@NitroDaves
Guest
Posts: n/a
It's all going to depend on the size shot you want to run and if the timing has been adjusted prior to you getting the nitorus on there. Just pulling out a couple of degree's for nitrous shouldn't hurt the car in any way when driving NA. You might lose a little power but thats about it.
Old Jul 10, 2010 | 05:42 AM
Datankid069's Avatar
Just to back up what Chris said: I'm tuned for a 75 shot. My car made 420rwhp NA, and when they pulled timing for the nitrous I ended up with 400rwhp. I use the car as a DD and I have no complaints. There's no sluggishness, no added wear and tear, just the convenience of being able to spray at a moments notice.
Old Jul 10, 2010 | 08:36 AM
This helps a little for me. But its a big turnoff to know my car is always going to be tuned "inbetween" and not how it should be if I had nitrous. Its turning me away bigtime. Ill probly just do stall and cam hmmm
Old Jul 10, 2010 | 09:06 AM
87silverbullet's Avatar
If you want the best of both worlds then just get a timing tuner or the lingenfelter box to pull the timing when you spray. I have the lingenfelter box and I pull 8 degrees on a 200 shot with it. When you are on the motor you have your N/A tune and when you hit the button it pulls the desired amount of timing for you.
Old Jul 10, 2010 | 10:13 AM
Alright now heres some info that really helps. So theres NOTHING else that changes in a tune n/a vs nitrous EXCEPT timeing?
