Trick Performance "trick box" window switch. NEED HELP ASAP!!!
Old Jul 9, 2010 | 08:39 PM
a.white86's Avatar
Default Trick Performance "trick box" window switch. NEED HELP ASAP!!!
My car wont spray for some reason. When we were first putting the kit on the car, we tested the solenoids and they clicked. Now, everything is on the car and everything looks to be powered and grounded correctly. The trick box comes on and everything, and the Arm switch is lit. All the settings in the Program section in the box are set up correctly.. Except for the last part I think.
Step #6 in the box is setting the WOT. It says push #2 button and floor it and press #1 right after to save that position and then it says END.
But when the switch is on and stuff, it displays 0L0. Any help is appreciated.. I'd like to spray the car soon but need help asap. If anyone wants to PM me a phone number and walk me thru it, that'll work too!
Old Jul 10, 2010 | 07:30 AM
Beer99C5's Avatar
Instruction set <---link to instructions set
Understanding LED readout.
Your window switch has an LED readout that not only is for programming but also tells you what your window switch is doing. From
confirming your rpm input set up is correct, to helping you diagnose a problem if one arises.
0 = Off, 1 = Activated, L = Locked
1st LED is your TPS, 2nd LED is stage 1, 3rd LED is stage 2
So if you read
0. 0. 0. then all items are OFF.
1. 0. 0. you have reached your TPS activation set point. No activation of system.
0. 1. 0. you are inside your RPM window. No activation of system.
1. L. 0. you have reached your TPS activation set point, but you are in gear locked mode. No activation of system.
1. 1. 0. you have reached your TPS activation and are inside your RPM window. ACTIVATION OF SYSTEM.
Old Jul 11, 2010 | 01:26 AM
a.white86's Avatar
Man I apreciate it so much! Everything is worked out now!
Old Jul 12, 2010 | 04:55 PM
Chris@NitroDaves
Guest
Posts: n/a
Good job on the post Beer....
Glad to hear it's all working correct now for you a.white86
