Quick question about wiring (using Timing Tuner & Trick Performance V gauge)
I am in the process of installing a Harris Speed Works wet plate kit on my 1999 Z28.
I will be using a Timing Tuner for these functions:
- RPM window switch
- timing retard
...and also a Trick Performance "V" gauge for these functions:
- air/ fuel gauge (I have a LC-1 wideband)
- bottle heater control with safety shut-off
- nitrous pressure gauge with programmable safety points
My question is: if I understand well, both the Timing Tuner (grey wire) and the "V" gauge (purple wire) need to connect to the same #85 pin on the nitrous relay, right? Is it OK to connect both on the same pin? I mean... the 2 devices won't interfere with each other, will they?
- RPM window switch
- timing retard
Truck Sponsor
Not sure what the timing tuner is doing with that input.
The purple wire is controlling the ground to the systems relay. In the event you hit a trip set point is shuts that wire ground off turning your system off.
If the timing tuners wire is doing the same thing as a shut down to that relay. YOU CAN NOT PUT THEM TOGETHER. You will need to run 2 relays in series so if either V or timing turner hit a trip point they can shut your system down.
Putting them together means they both have to trip to shut your system down.(not safe) Series allows either to do it..
Thanks guys!
The Timing Tuner cuts off nitrous before and after set RPMs (acting as a RPM window switch), therefore it sounds like I'm gonna have to run 2 relays in series as you suggest. Thanks so much for your help.
