Resistor Mod (Yeah I know again)
My question is this:
I have an NX Wet ket. I would like to use the resistor mod to pull timing when the noids spray. I'm going to be using a window switch set for 3500-6000 RPM.
I can't really tell from the diagrams I've seen if this can be done to run off the noid or do I need a separate switch to activate the relay. And which relay do I use?
Am I completely lost here?
Thanks
Sarge
I'm doing my own diagram for an 02 Z06. I'll take install pics as well for others that have the same questions I did.
I color coded the A and B for easier identification for my model year.
