C5 Z06 NX 150 Wet kit Install begins.
Old 08-09-2010, 11:57 AM
SargeZ06's Avatar
Originally Posted by NitrousExpress
Go ahead and give it that full extra turn. It will be fine sir.
Ah now that's better. Much better. Thanks
Old 08-10-2010, 12:16 PM
SargeZ06's Avatar
Got the N2O and purge noids installed. I gave up on trying to stuff them under the passenger fuel rail cover. I think this looks cleaner.
Old 08-11-2010, 09:32 AM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
Great looking engine bay. This thing will look really great when its all wrapped up.
Old 08-11-2010, 10:44 AM
Nitro Dave's Nitrous Outlet's Avatar
Install is turning out nicely. I will make a couple of suggestions.
Clock the bottle so that the bottle nipple is rotated down and at the rear of the car. This will make sure the pick up tube grabs the liquid as the g-force of the launch pulls it to the back of the bottle.
Where you have the nitrous solenoids mounted the 16ft main feed line that comes standard in the kit will not be long enough. It may be close if you swap the bottle around and run the feed line down the drivers side of the car instead.
Sticking with your plan what I would suggest is picking up a filter and an extention line the lenth you will need. You really need a filter anyways.. Then you can come off the bottle with the extention hose to the filter and then connect your main feed line on the oposite side of the filter.
This is the filter I would suggest. You can take it apart and clean it through out time. We can build the hoses to any lenth you may need.
http://www.nitrousoutlet.com/catalog...7&product=2765
Dave
Old 08-11-2010, 10:52 AM
dnkynrbk's Avatar
Starting to look sweet man congrats. Let me know when you get to the track and get some slips.
Old 08-11-2010, 01:45 PM
SargeZ06's Avatar
Dave
I already have a filter and a 24" extension line for that.
I have this filter. http://www.summitracing.com/parts/NOS-15550NOS/
Do you still think I will have a problem with length?
Old 08-11-2010, 04:26 PM
SargeZ06's Avatar
Okay feed line run. I had exactly enough line. Ran through the main harness grommet under the battery, under rocker trim, up trim piece along door sill and under carpet to bottle. Now just gotta do all the damn wiring...
Old 08-11-2010, 05:59 PM
Good deal.. Nice job..
Old 08-12-2010, 04:09 AM
Luckymex_dallas's Avatar
Thanks For The Inspiration!
Old 08-12-2010, 10:17 AM
Looking better and better with every update sir. Thanks for posting up all the pics. Let me know if you need anything else ill make sure we show our appreciation.
Old 08-12-2010, 11:56 AM
SargeZ06's Avatar
Thanks NX. I ran the wires for my N2O and Fuel noids. Soldered and double heat shrinked the joints. My relays will be mounted in the battery box. This is just a rough layout right now. I still have to run the purge noid wires and put them all in convoluted tubing and tuck away under the cowl. But you get the idea.
Old 08-12-2010, 12:19 PM
  #32
8 second mod
Noyzee's Avatar
did you make those rear covers to make the trunk flat? i like that a lot!!!
Old 08-12-2010, 02:00 PM
  #33
SargeZ06's Avatar
Thanks. Actually it is out of my 03 C5 coupe that I totaled. I have the 2 side compartment covers too.
Old 08-12-2010, 02:11 PM
  #34
8 second mod
Noyzee's Avatar
i like that a lot, i think i might try to make those, that way the trunk looks clean, i can toss my towels and cleaning **** down there
Old 08-12-2010, 08:39 PM
  #35
SargeZ06's Avatar
Did a little clean up. Gotta stop for now. Gonna spend tomorrow cleaning the car for a show.
Old 08-13-2010, 06:04 AM
  #36
SargeZ06's Avatar
I don't think I like the way it looks. I'm gonna change it.
Old 08-13-2010, 08:46 AM
  #37
SargeZ06's Avatar
Okay I think this looks better. Sorry if you hate looking at pics then you should avoid my threads. I took these with a Nikon instead of my crappy Blackberry.
Still a long way to go...
Old 08-13-2010, 09:52 AM
  #38
Ray@Nitrous Outlet
Guest
Posts: n/a
very nice....its the little details that make a "clean" install.
Old 08-13-2010, 01:37 PM
  #39
Beer99C5's Avatar
Great Job!
Old 08-13-2010, 03:26 PM
  #40
Very nice work man. If you want any decals or a shirt let me know.
Quick Reply: C5 Z06 NX 150 Wet kit Install begins.
