how to connect this ????
Old Aug 6, 2010 | 07:52 AM
same o'j's Avatar
Default how to connect this ????
finally i got my V-plus volt Booster ( 102130 )
but i wondering about how to plug the TPS , because i already connect the
the window switch signal with blue wire in TPS harness , so can i keep every thing and only plug the TPS with the volt booster direct or i should transfer the window switch to the new TPS plug in the v-plus volt booster ???
i guss maybe both will give the same signal to the Window switch ??
what you think guys
Old Aug 6, 2010 | 04:28 PM
Nitro Dave's Nitrous Outlet's Avatar
You can share the same connection as long as you have good contact.
Dave
