How many pulls do you guys get out of a 150 shot in a 15lb bottle?
On a 150 shot you should be able to get at least 5 good 1/4 mile pulls out of a 10lb bottle, so using a 15lb bottle, you ought to be able to get about 9 passes. Hell a full pull should only use a lil more than a lb. Just my 2 cents.
IWGF, I hope what you are getting out of a bottle isn't average. I hope krissoto is more correct, I'd like to at least get a whole track day out of a 10 lb'er at 150 shot. I can usually get 5-7 passes in at the track, would be disappointing if it was done on a just a handful of passes! I've got NANO, just need to finally install all this.
Get a nano setup as previously stated... that will make it so ur only using roughly .5 lb per 10sec per 100hp. Basically if ur getting 4 -5 passes with the 150, youll see about 8-10 passes with nano before the bottle runs out. Im only speaking from other people results, I still have yet to finish my setup .
