please help nos 15982 2 stage window switch
Old Aug 8, 2010 | 11:07 PM
260B4U's Avatar
Default please help nos 15982 2 stage window switch
ok si i wires it all up and i only have a single stage to run 100shot nano kit
and i cant get it to switch to stage 1 only stage 2 and stage 2 isnt wired up
so how do i get it to switch to stage 1 it just has 2 buttons s o thought i could just hit the stage 1 button but apparently not ! please help before i rewire to stage 2
tia
Old Aug 11, 2010 | 10:54 AM
dnkynrbk's Avatar
This is the nos mini right? Im at work and dont have time to access their sight? I can help you wire it up if it is I just finished wiring one up last week.
Old Aug 11, 2010 | 11:02 AM
Nitro Dave's Nitrous Outlet's Avatar
If for some reason the stage 1 is bad in the switch you will have to un wire it and wire up the stage two in order to use it instead.
In order to enter program mone you will push and hold both button 1 and 2.
Are you sure you have everything programed correctly? Have you varified the RPM and TPS settings and connection?
Here is the instructions incase you do not have them.
http://www.holley.com/data/Products/...R10482rev3.pdf
