Will i need to retune?
http://www.nitrousexpress.com/produc...ls.php?id=1483
The heat range 6 non projected plug will be o.k., but ONLY WITH A 100 HP LEVEL. Anymore then that puta #7 heat range in the car.
Standalone is a nice setup, but might be a bit much for the initial setup. Start trying to put 150 to 200 to the car, along with a cam, so it's up in the 500 rwhp range + then I would absolutely put a standalone in the car.
Alot of this info is in the sticky above.
They aren't going to foul, hurt performance, etc (unless your tune is too rich in the first place)...
I drive mine on the street all of the time with 9's in it and have never had any of these problems that people worry about with a colder race plug.
+1 on the standalone being overkill.... Also not liking the suggestion for other reasons....
I ran #9's in my car on the street and it was fine, but that was a 13.5 to 1 race fuel deal.
#7 will be fine, like said, it's only going to give you problems if your idle tune is way off.
http://www.holley.com/05168NOS.asp
what other things need to be bought for a complete, safe, installation? Im thinking FPSS and a bottle heater for sure... anything else? I have to get a racetronix fuel system for a 100 shot as well correcct? and also, i didnt see in the description, and forgot to ask the seller, but how is this system activated?
Put a good pump (or two) in the tank.
That system's only activated by a wot switch. I'd ditch that and get a controller like Nitrous Outlet sells that allows you to use your TPS and RPM signals to activate the kit. A good nitrous filter will also be a major necesisity.
A heater is very important as said. If you are looking for an package deal we offer them as well.
Best of luck with your setup. If you need help with anything or a second opinion just let me know sir.
