Wheres a 12v source always on?
Old Aug 9, 2010 | 07:31 PM
TA1364's Avatar
Default Wheres a 12v source always on?
Im trying to wire a eletric pressure gauge and its asking for a 12v source that is always on even when the ignition is off. Where is something like this at?
Old Aug 9, 2010 | 07:40 PM
TA1364's Avatar
Also, where is a wire to connect to 12v dash lighting?
Old Aug 9, 2010 | 08:29 PM
DopeFedZ's Avatar
You should be able to get a constant 12 volt source from one of the fused spots in the fuse box on the side of the dash or you can run a wire up to the battery. 12v dash lighting will be the green wire coming out the plug harness that goes into the back of the light switch.
Old Aug 9, 2010 | 09:58 PM
TA1364's Avatar
Gauge is working but its 50 psi off from the bottle gauge. Light isnt working either.
Old Aug 9, 2010 | 10:36 PM
DopeFedZ's Avatar
What gauge are you using.
Old Aug 10, 2010 | 08:09 PM
TA1364's Avatar
Marshall
Old Aug 11, 2010 | 06:37 AM
JL ws-6's Avatar
Race your car!
You don't really want it on a non-switched power source, it becomes a drain at that point...
If it's 50 lbs off, try checking it with another bottle.. make sure it's not the bottle ga that's off.
If it's still off... I'd return/ditch it. 50 lbs of bottle pressure is enough to effect a tuneup some, depending on how much you're spraying and how close your tuneup is.
