Clearances good for Shot?
Old Aug 17, 2010 | 09:47 PM
HPFreak's Avatar
Default Clearances good for Shot?
stock sleeved ls2 callies crank, compstar rods, diamond pistons .018 .022 gaps....what size shot?
Old Aug 18, 2010 | 08:23 AM
ryarbrough's Avatar
Which rings? Steel top ring?
Old Aug 18, 2010 | 08:30 AM
HPFreak's Avatar
Standard ring setup that Diamond come with.
Old Aug 18, 2010 | 08:37 AM
ryarbrough's Avatar
what's the part number on the pistons?
Old Aug 18, 2010 | 08:49 AM
ryarbrough's Avatar
Just so you know now... Those gaps are tighter that I'd like for big shots of nitrous (I'm assuming a 402 here), especially if it's a steel top ring... what's the bore? ci? Also the Diamonds can come with two different ring packs. Which one did you get?
Old Aug 18, 2010 | 09:37 AM
HPFreak's Avatar
Yes it is a 402. Built it a couple years ago. Ill have to do some digging but im sure i can find the build sheet. Not sure what ring kit was used or the part number of the top off my head.
Old Aug 18, 2010 | 09:47 AM
ryarbrough's Avatar
Yeah... That ring gap is pretty tight for nitrous use, especially if it's a steel top ring... Light use would be ok, but I'd be concerned about breaking a ring due to expansion of a steel top ring if you hit it hard..
Old Aug 18, 2010 | 10:27 AM
HPFreak's Avatar
i was thinking 150 AT MOST!
Old Aug 18, 2010 | 10:29 AM
ryarbrough's Avatar
PSH.... Nevermind then.... It'll be fine. Just keep an eye on the tuneup and all will be good.
Old Aug 18, 2010 | 04:20 PM
Chris@NitroDaves
Guest
Posts: n/a
I'm with Ryarbrough on this one...as long as the fueling and tune are there you should be fine on teh 150hp shot.
Old Aug 18, 2010 | 04:43 PM
Brad@NANO Direct's Avatar
150 shot? That's just an appetizer.
Old Aug 18, 2010 | 06:54 PM
HPFreak's Avatar
OK so the rings are off the shelf standard mahle. As for the piston part number, I do not have it.
