New Best
Old Aug 18, 2010 | 09:28 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
Default New Best
Last weekend I went up to Dallas raceway with Kyle and Tony as they tested their new combos for the upcoming LTx Shootout. Took the car up since I was going to have a little fun. Knew my bottle was low but figured I had enough to make 1 nitrous pass................bottle gave out around the 1000' mark but was still able to click off a new best 1/4 ET.
60' 1.424
330' 4.075
1/8 ET 6.303
1/8 MPH 111.83
1000 8.207
1/4 ET 9.826
1/4 MPH 132.02
http://www.youtube.com/watch?v=Ckv_S0DueLI
http://www.youtube.com/watch?v=sb-hLlQ9RCA
Looking forward to Sept 4th and setting the car on kill...
Old Aug 18, 2010 | 10:15 PM
YURVIEW's Avatar
Damn Man...... Stupid FAST!!!! I can only Dream!!!
Old Aug 19, 2010 | 05:15 AM
Firehawk441's Avatar
Nice job... Congrats.
Old Aug 19, 2010 | 06:14 AM
BAKED's Avatar
Sounded like it was breaking up a bit?
Old Aug 19, 2010 | 07:11 AM
Nitro Dave's Nitrous Outlet's Avatar
Probably from going rich due to the bottle going empty.I just listen to the video and hear it to.
Old Aug 19, 2010 | 07:14 AM
Ray,
Congrates on the new best... It still amazes me that this bottom end was put in back when I had the speed shop down on franklin. I do not know another Nitrous car that has had the same short block with our being freshened up for the same lenth of time.
Dave
Old Aug 19, 2010 | 07:24 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
Yep...the shortblock was assembled back in the summer of 2003, and has had multiple heads/cams combintations ran on top of it. Plans areto pull it out and freshen it up for next year.
Old Aug 19, 2010 | 07:34 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
good ear....the car did surge once shortly after launch, hit the limiter on the 2-3 shift, and then really broke up on the big end when the bottle gave out. I was trying to stay as close to WOT as I could to attempt to get through the traps.
Going to raise the rev limiter a bit for the LTx Shootout to give me a little more room...right now I only have 200 RPM between the shift point and the rev limiter. I have kept raising my shift point and the car keeps dropping ET.
Old Aug 19, 2010 | 07:57 AM
Brad@NANO Direct's Avatar
Looking good Ray
Old Aug 19, 2010 | 07:59 AM
It has served you well.....
Old Aug 19, 2010 | 08:03 AM
Tony Shepherd's Avatar
Congrats Ray!
Old Aug 19, 2010 | 04:54 PM
Chris@NitroDaves
Guest
Posts: n/a
Congrats on the new best Ray!!!!
Old Aug 19, 2010 | 05:10 PM
AChotrod's Avatar
Congrats!!!
Old Aug 19, 2010 | 07:15 PM
Carter01's Avatar
Great job man! Any specs on the car?
edit - just watched it again, that was off the footbrake also. Very nice!
Old Aug 19, 2010 | 09:06 PM
S197pilot's Avatar
Congrats Ray!!!
Old Aug 19, 2010 | 09:10 PM
dnkynrbk's Avatar
Congrats RAY.
Old Aug 19, 2010 | 09:24 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
quick rundown..let me know if you want to know anything else
396cid, eagle crank, eagle 6" rods, Ross Pistons
AFR 227 Heads, T&D Shaft Mounts
246/254 .613/.590 112 HR
Edelbrock Vic-E EFI, BBK 58mm TB, N2O Elbow
OEM PCM, MSD Opti, MSD Digital 6
700r4, 3000ish stall w/lockup
Moser 12 bolt, 3.73s, posi
Spohn Tq Arm, panhard, Billet LCA w/heim joints
QA1 Shocks, single adjustable
3220# Raceweight
Yes it was on a foot brake....I launch from right above idle, converter flashes to ~5500. Car will cut mid 1.3 60's with a little tuning for track conditions. I needed a little less tire pressure than what I ran on that pass. (20 psi).
Old Aug 19, 2010 | 09:30 PM
MYSTIC-1SC's Avatar
congrats on the pass... Cant wait to see what it runs on a full bottle.
Old Aug 19, 2010 | 09:44 PM
robsquikz28's Avatar
Hell yea bad *** car and cant w8 to see what it does for real
Old Aug 20, 2010 | 02:44 PM
Chris@NitroDaves
Guest
Posts: n/a
