Nitrous line leak issue!
Old Aug 21, 2010 | 02:37 PM
MYSS02's Avatar
Default Nitrous line leak issue!
Can I replace the end connection that connects to the bottle?
Do, I really need to replace the full line from bottle to engine connection area? if I do replace the entire line, should I put in a extra short line connection at the end incase this happens again?
Thanks Robert
Old Aug 21, 2010 | 03:09 PM
ryarbrough's Avatar
You can have a new end crimped on... Most industrial fitting/hose aces can do it. Just make sure you tell them to make sure it's a fitting good for 1500+psi just in case you have some freak overpressurization
Old Aug 21, 2010 | 03:17 PM
MYSS02's Avatar
Thanks!
Old Aug 22, 2010 | 03:18 AM
dnkynrbk's Avatar
I had my done by a local shop called speedco. They do brake lines. They just cut the bad end off and replace it with a new line.
Old Aug 22, 2010 | 01:19 PM
MYSS02's Avatar
Thanks... for even more help!
I now two more plans, the first one failed yesterday.
The first one was a weak plan, at the end of the day... just want my bottle back.
Thanks guys for the two great plans!
Robert
Old Aug 23, 2010 | 10:44 AM
Nitro Dave's Nitrous Outlet's Avatar
Robert
You can send us the hose and we can replace the end or we stock fittings you can buy to replace it your self.
Dave
