Spraying on the brake
Old Aug 29, 2010 | 06:22 PM
subhumanzz's Avatar
Default Spraying on the brake
i dont have a 2 step on the car so when i am on the brake can i just flat foot the skinny pedal and let it start spraying before the light goes green or do i need to wire in another relay? im only spraying a 100 on it and didnt know if it would have any ill effects or not. on the brake the converter will go to 4400 na and around 5200 on the spray. the last time out i didnt try using the brake in conjunction with the n2o. i was foot braking it to 2500 and then just going wot after that to engage the nitrous. best 60' with this method was a 1.44. i think it will leave harder with the brake but just wanted to make sure i was ok to do so. thanks for the help.
Old Aug 29, 2010 | 08:33 PM
Carter01's Avatar
Add another relay (n/c) so when you press the TB button the n20 is not active but the TB is then as soon as you release the button it activates, probably $30 bucks worth of parts. I just changed to this method and it knocked off about a tenth in my 60ft. I ran consistent 1.48, 1.45, 1.44 60s last Friday night. Since your car is already in this range it's very possible you will go 1.3s...
Old Aug 29, 2010 | 08:38 PM
subhumanzz's Avatar
i know about that but was curious as to whether or not there would be any ill effects from just spraying while im up on the converter at the line. for a second or less before the green comes on. i guess i will just have to wire in another relay. where can i find a good schematic for doing this?
Old Aug 29, 2010 | 08:42 PM
subhumanzz's Avatar
i have this one saved but i dont think it would be the same being as i am running the microedge and everything goes though it.
http://coldfusionn2o.com/wiring_ints...transbrake.gif
Old Aug 29, 2010 | 09:48 PM
ATVracr's Avatar
Done it before.... makes alot of noise because the 2 step is dropping random cyl.
But the car left HARD !! I talked to Jeff Prock about it and he said it wouldnt hurt anything but we dont need the car to leave that hard so we dont do it.
Old Aug 29, 2010 | 10:22 PM
dnkynrbk's Avatar
I wired mine to the relay and when I have the transbreak pushed it doesnt spray until I release the trans break then it sprays right off the line. My full weight car pulls a 1.32 60ft with a stock k member and a arms. I just have QA1s thats it.
Old Aug 29, 2010 | 10:28 PM
dnkynrbk's Avatar
you have a PM
Old Aug 30, 2010 | 05:20 AM
subhumanzz's Avatar
I do not have a 2 step. It will be spraying right when I floor the car on the brake.
Old Aug 30, 2010 | 06:24 AM
ATVracr's Avatar
Be fine just dont stand on the brake to long.
Old Aug 30, 2010 | 07:45 AM
ryarbrough's Avatar
Agree with ATV. I could only imagine how hot the fluid would get if you're on the brake spraying more than a second or so...
Old Aug 30, 2010 | 08:08 AM
subhumanzz's Avatar
If i stage the car and wait for the first yellow then floor it I should be fine then. I am running the micro edge as nothing more than a glorified window switch. I may just put in a regular ws and eliminate the micro edge. any suggestions on a ws? I think this will simplify the wiring a bit.
Old Aug 30, 2010 | 08:43 AM
ATVracr's Avatar
Better tighten the front susp. up .... if its on radials you may see a little bumper action. LOL
Old Aug 30, 2010 | 09:00 AM
ryarbrough's Avatar
LOL... If it hooks it will be nasty...
Old Aug 30, 2010 | 09:43 AM
subhumanzz's Avatar
With a 1.44 60' it only lifts a couple inches ( shocks on a 1 ). i don't think it will go on the bumper. ill let ya know Thursday.
Old Aug 30, 2010 | 10:17 AM
ryarbrough's Avatar
I'd tighten em up just in case.... Stuff gets expensive quick when they come crashing down from bumper riding incidents.
