N20 outlet solenoid bracket
Old Aug 30, 2010 | 10:47 AM
Shownomercy's Avatar
Man-Crush Warning
Default N20 outlet solenoid bracket
I have their LT1 plate kit, and finally got around to buying the plate and hardline kit to make mine look halfway decent. My question is, the plate and the lines should include everything I need correct?
I know I need to flare the lines, thats not a problem, just making sure I don't need to order anything else. Thanks.
Old Aug 30, 2010 | 01:52 PM
Chris@NitroDaves
Guest
Posts: n/a
With the hardline kit you won't have to flare anything...that comes done for you. All you would need to do is bolt everything on.
Old Aug 30, 2010 | 02:20 PM
Man-Crush Warning
Ah ok, sweet!
How long is shipping roughly? Ordered em on the 26th.
Old Aug 30, 2010 | 04:40 PM
AChotrod's Avatar
Make sure you have the compression fittings
Old Sep 2, 2010 | 02:31 PM
Man-Crush Warning
Guess I have an older kit, fuel noid does not output through the base, so just grabbed a 90degree from the depot.
Old Sep 3, 2010 | 02:12 AM
robsquikz28's Avatar
what compression fittings did you use?
Old Sep 3, 2010 | 02:58 PM
Grant@NitroDaves's Avatar
LS1TECH Sponsor
We redid our fuel solenoids with the bottom exit about a year ago +/- so we could make specific hard-lined kits for the most common applications.
Old Sep 3, 2010 | 09:44 PM
Man-Crush Warning
Yea, figured as much, I sent you guys an email, but I can ask on here as well...
Is there a hardline you guys sell that will make this work? I know on Formula383's car he has the older style solenoid
Can I buy that hardline? And then in relevant topics, on the main nitrous solenoid, there are two inlets, can I use one for a purge?
Old Sep 4, 2010 | 08:36 PM
LS1TECH Sponsor
We could probably mock one up and bend it for you. The hardline like Kyles was not specked out, it was a custom deal for Kyle.
And as far as the solenoid inlets, the 1/4NPT is specifically for the feed line and the 1/8 is for purge.
