Want to hide my kit
Old Feb 22, 2011 | 09:16 AM
  #41
Nitro Dave's Nitrous Outlet's Avatar
Originally Posted by Killer5.3
How easy are jet changes with the money maker , how much $$ , and how long is turnaround time once you get intake? It's an LS6 intake
Shoot me a pm with any questions you have. I will answer what I can.
Thanks
Dave
Old Feb 22, 2011 | 12:26 PM
  #42
Killer5.3's Avatar
Thanks
Dave
I sent Grant a pm. He sent me some info today. Hopefully be contacting you soon about purchasing what I need.
Thanks
Old Feb 22, 2011 | 01:18 PM
  #43
1lejohn's Avatar
Originally Posted by firechkn83
we used the roll cage as the bottle by capping the inside and running lines through inside of pipe and hiding solenoids in heater box
Thats what I was thinking. It seems some Dodge Pro Stock team did it back in the late 90's. I can't think of their name. They clamied some body broke into their shop and broke their engines so they had to drop out the rest of the season. It also seems Bob Glidden was accused of spraying his cars.
Old Feb 23, 2011 | 01:22 AM
  #44
slowblackbird's Avatar
i use to run a couple of bottles mostly one in the back glass and one in the spare tire well, when they see the one in the back glass and see you turn it off and disconnect the line from the bottle they never asked any questions about another bottle
Old Feb 26, 2011 | 06:58 PM
  #45
HoLLo's Avatar
I just thought of something... Maybe get a spare backseat seat cushion from a junk car, and cut a bunch of foam out of the bottom to see if you can fit a bottle in it while still being able to put the seat all the way down. Anyone try that? or could a bottle even fit under???
Old Feb 26, 2011 | 07:29 PM
  #46
tripblackls1's Avatar
i have a hidden dry shot that had a bottle in the rear bumper, held on by large hose clamps (i know its getto but it worked)then my solenoids were in the glove box with a pressure gauge and the line went into the pcv line at the tb and was covered by a hose and look just like stock
this was also using a hsp interface
i had many gm ppl look for it (even shop owners) and nobody found it
Old Feb 27, 2011 | 02:14 PM
  #47
1lejohn's Avatar
If you have been around you can tell when some one has doped you. The rpms pick up and usually a blast comes out the pipe. Now bracket racing against guys that sand bag you is fun with a small shot. They come up and fender you untill you hit the gas and you pull by them. That look they have is classic. Then they have to stomp it to catch up which throws them off their time. Can u say break out.
Old Mar 2, 2011 | 09:27 AM
  #48
ShortChevy's Avatar
Bottle in the bumper? Hope no one ever rear end's you lol. That would kinda suck.
Old Mar 2, 2011 | 07:12 PM
  #49
BadAZ's Avatar
Originally Posted by jt76
I wonder if a bottle will fit under my dash? I have my HVAC removed.. hmmmm
Yep. 5 lb FTW!! lol I did that on an old Fox of mine with a 10 pounder.... helluva lot o' fun!
Old May 15, 2012 | 04:52 AM
  #50
ZTwentyAteU's Avatar
Its kinda hard to hide a wet kit..but a dry kit is easy. Just pop the nozzle through the air filter and hide the solenoid up in the front bumper.
The best way is just install the kit normal. Get a tunnel mount bottle bracket, leave the bottle out of it, and let an unhooked nitrous line lay on it. Run your bottle in the spare tire well. If someone asks, point at the bracket inside and tell them your not spraying that day....done it before haha
Old May 16, 2012 | 08:12 AM
  #51
Turbo306Fox's Avatar
Lol did it just last weekend ^
Old May 16, 2012 | 06:07 PM
  #52
Sadden's Avatar
4 of those sneeky pete bottles would be perfect for a hidden dry system.
